Mowing What size bush hog is best suited for use on a BX23?
   / What size bush hog is best suited for use on a BX23? #11
If your worried about HST fan a quick simple solution is 3/4 inch plywood hung underneath via pipe strapping to exisiting holes in frame , cut out a section for the filter. Takes five minutes to take on an off the four 1/4 inch bolts , you can adjust it up tight easily to have it barely noticeable yet still protect I added a piece of sheet metasl at end to prevent sticks from getting thru sideways........and if you are driving anywhere that a stick can go thru 3/4 inch plywood , then you should not be there. I use mine on my ATV trails thru dense bush, plywood has a few gouges thats it.
2019 Caterpillar 259D (A53317)
2019 Caterpillar...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
CFG Industrial H15R (A56469)
CFG Industrial...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
Horse Statue (A55853)
2015 Chrysler Town & County Van (A55853)
2015 Chrysler Town...
