Mowing What size bush hog is best suited for use on a BX23?
   / What size bush hog is best suited for use on a BX23? #11
If your worried about HST fan a quick simple solution is 3/4 inch plywood hung underneath via pipe strapping to exisiting holes in frame , cut out a section for the filter. Takes five minutes to take on an off the four 1/4 inch bolts , you can adjust it up tight easily to have it barely noticeable yet still protect I added a piece of sheet metasl at end to prevent sticks from getting thru sideways........and if you are driving anywhere that a stick can go thru 3/4 inch plywood , then you should not be there. I use mine on my ATV trails thru dense bush, plywood has a few gouges thats it.
2005 Chrysler Town and Country Limited Van (A55853)
2005 Chrysler Town...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
UNUSED FUTURE GR87-87" HYD GRADER BLADE (A57193)
UNUSED FUTURE...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A55852)
2004 Pierce Tilt...
