Box Scraper What size box blade????
/ What size box blade???? #1
fordman6442
Terrace B.C. Canada
67 massey 165,1947 Farmall A, 1949 Massey Harris, 1955 Ford 600 with b/hoe and loader J.D. 350 Crawler with winch and 6 way blade,Kabota riding mower, Husquavarna riding mower,Kawasaki quad and a wife
I have a Massey 165(1967) and wonder what size box blade it will handle. I have plans for a couple blades but don't know what to build. My tractor is about 6'4" outside the rear wheels. Any ideas????
/ What size box blade???? #2
Should be sufficient weight and horsepower (especially if you have the Perkins) for a six and a half footer. It'll cover your tire tracks too. Don't know if they're still making them, but Bush Hog and LandPride used to sell 78 inchers.
//greg//
/ What size box blade???? #3
Good Evenin Fordman,
I agree with Greg, that tractor has enough of HP to pull a 78" boxblade if you have good rear tires. You might even get away with a 7 ft blade ! ;)
/ What size box blade???? #4
A seven footer will not be a problem for a 165 -- my anemic gas 135 will pull a six footer:p and you want the blade outside the wheels
Thanks guys I will go with the 78". The plans I have are only for a 4' and 5' using 1/4 plate. I know I can use these designs to go bigger but should I go to 3/8 plate or just beef the back and ripper section up a bit.:D:D
/ What size box blade???? #6
1/4"??? for a 78" box? You should go to 1/2" construction for all parts. Especially for middle of box front to back support. There is a lot of span from end to end and it will bend when you hit that first large rock or root if you don't. Study your plans then inspect industrial boxes and see how they differ and select design elements that you want.
jb
/ What size box blade???? #7
Sage advice from John, sounds like he's already "been there, done that". My first BB underwhelmed me, I felt like I was supporting the local fabrication shop. So when it came time to replace it, I already knew some of the structural weaknesses to avoid.
The recommendation that tops my list, is to fabricate the beefiest lift frame possible. This is the type I have on my current BB. Haven't hit anything that could bend it yet......
//greg//
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
New/Unused AGT Industrial Gas-Powered Air Compressor (A61166)
New/Unused AGT...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
429651 (A61165)
429651 (A61165)
2017 Kubota SVL 75-2 Skid Steer (A61166)
2017 Kubota SVL...
2024 BOBCAT T66 R-SERIES SKID STEER (A62129)
2024 BOBCAT T66...
