What size bolt/pin for Cat 1 3pt QH top HOOK
   / What size bolt/pin for Cat 1 3pt QH top HOOK #1
Atchuuu
Kubota L4330 HSTC
Lost the top hook on my quick hitch. I am ordering a new one and would like to use some type of hitch pin rather than bolts. Can you tell me what size pins I need for a Cat 1 application?
   / What size bolt/pin for Cat 1 3pt QH top HOOK #3
The top-link bolts/pin is 3/4 diameter. The bushing that fits the top hook on the quick hitch that you have pictured is 3/4 ID and 1-1/4 OD
   / What size bolt/pin for Cat 1 3pt QH top HOOK #4
Those holes are 1/2" on my top hook. I think bigtiller is referring to the wrench size on a 1/2" bolt head.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #5
I was in a different hole. But you're correct, the bolts that hold the hook to the hitch are 1/2". The pin that holds the top link to the hitch are 3/4" . And the hook uses a 1&1/4 OD bushing.
I think I misunderstood the OP's question.
Thanks to all. Answered my question.
I hate to think that I will likely find the missing top hook when bush hogging again. It's in the grass somewhere.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #7
Shouldn't be too hard to spot. I would walk it good with another pair of eyes.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #8
Walk ares where you think you lost it with metal detector, --- Don't have one, borrow one...
Dale
Dale
I was going to reply to your message yesterday and tell you how unlikely it would be for me to find the top hook given that I have 15 acres and had run all of it with the tractor. No way would I have tried searching with a metal detector
Then today I got out of my truck and walked to a tree so I could continue my phone call in the shade. While on the phone I looked down at my feet and there was my top hook. No looking required.
Do any of you run the bush hog without the top link connected? If so what are the pros and cons? I found that the cut was better without the top link on.
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2021 Caterpillar 259D3 (A53317)
2021 Caterpillar...
UNUSED FUTURE PAIR OF 7" MINI RUBBER TRACKS (A57193)
UNUSED FUTURE PAIR...
2020 DRAGON ESP...
UNUSED FUTURE HYD MINI THUMB CLIP (A57193)
UNUSED FUTURE HYD...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
