What size bolt/pin for Cat 1 3pt QH top HOOK
   / What size bolt/pin for Cat 1 3pt QH top HOOK #1
Atchuuu
Gold Member
Kubota L4330 HSTC
Lost the top hook on my quick hitch. I am ordering a new one and would like to use some type of hitch pin rather than bolts. Can you tell me what size pins I need for a Cat 1 application?
   / What size bolt/pin for Cat 1 3pt QH top HOOK #3
The top-link bolts/pin is 3/4 diameter. The bushing that fits the top hook on the quick hitch that you have pictured is 3/4 ID and 1-1/4 OD
   / What size bolt/pin for Cat 1 3pt QH top HOOK #4
Those holes are 1/2" on my top hook. I think bigtiller is referring to the wrench size on a 1/2" bolt head.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #5
I was in a different hole. But you're correct, the bolts that hold the hook to the hitch are 1/2". The pin that holds the top link to the hitch are 3/4" . And the hook uses a 1&1/4 OD bushing.
I think I misunderstood the OP's question.
Thanks to all. Answered my question.
I hate to think that I will likely find the missing top hook when bush hogging again. It's in the grass somewhere.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #7
Shouldn't be too hard to spot. I would walk it good with another pair of eyes.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #8
Walk ares where you think you lost it with metal detector, --- Don't have one, borrow one...
Dale
Dale
I was going to reply to your message yesterday and tell you how unlikely it would be for me to find the top hook given that I have 15 acres and had run all of it with the tractor. No way would I have tried searching with a metal detector
Then today I got out of my truck and walked to a tree so I could continue my phone call in the shade. While on the phone I looked down at my feet and there was my top hook. No looking required.
Do any of you run the bush hog without the top link connected? If so what are the pros and cons? I found that the cut was better without the top link on.
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
UNUSED FUTURE LS43 HYD WOOD SPLITTER (A57193)
UNUSED FUTURE LS43...
JOHN DEERE 333G SKID STEER (A52707)
JOHN DEERE 333G...
2015 Autocar Xpeditor T/A E-Z Pack 40 Yard Front Loader Garbage Truck (A55852)
2015 Autocar...
2005 Ford Taurus SE Sedan (A55853)
2005 Ford Taurus...
2024 CRATOS ES-800 ELECTRIC DUMPER (A57192)
2024 CRATOS ES-800...
