What size are these hooks?
/ What size are these hooks? #1
Dougryan
Bronze Member
Webster, NY
Cub Cadet 3206
I recently bought a tractor that has hooks welded to the bucket. No marks on the hooks telling me what size they are.
I believe they are 1/2". Is that correct? Planning to buy a chain and want to get the right size.
Thanks.
/ What size are these hooks? #2
Those do appear to be half inch hooks. You could use half inch chain but if you go down one size they'd probably be easier to work with.
/ What size are these hooks? #3
Can you read whatever is cast into the hook? May help. I'm guessing they'd work better with 3/8".
/ What size are these hooks? #4
Standard hook opening measurements are as follows:
Chain SizeHook opening
5/163/8
3/87/16 to 1/2
1/25/8 to 11/16
This can be verified by checking hook drawings and dimensions in the McMaster-Carr catalog, which is from where I lifted this information.
/ What size are these hooks? #7
Depends on what you're doing with the chain, but I wouldn't want to be working with more than 5/16 chain on a regular basis around the farm. I go 3/8 on occasion but with 1/2 chain I'd need some help moving that around. And don't bother with the cheap chain. I wouldn't use anything less than a Grade 70 chain in any of the sizes. Or Grade 80 if you're doing any overhead lifting. Cheap chain can kill you if it breaks, even if you're 20' away.
/ What size are these hooks? #8
3/8 is a good all around size. I've had 5/16ths and it doesn't take much to stretch it. The 3/8 is a bit clumsier but is almost always up to the job
/ What size are these hooks? #9
Depends on the tractor. I have a dozen 5/16” chains, and really like that size, as it’s so much lighter than 3/8”. I don’t often get into lifting or dragging items, where 5/16” is not sufficient.
When it comes to strapping down loads, I have a box full of 2” ratchet straps of various grades. I’m not hauling coil steel on semi trucks, size your chain and straps accordingly.
/ What size are these hooks? #11
Chain gets heavy fast; 3/8" will do most jobs.
I have a 92' 5/16" chain that I pull big blackberry brambles with, but that's not a high-tension thing to do.
/ What size are these hooks? #12
Regarding the weight of different size chains, I put this together a few years ago and have other info on our FAQ page.
Not surprisingly, they all hold around .005 lb/in2 link cross section, which means they should also all have similar breaking strength to weight ratio. Not a surprise, assuming the weld is stronger than the bulk, it just comes down to the ultimate tensile strength of the material from which they're made.
Reinforcing my prior point, 3/8" is 45% heavier than 5/16". If you don't need that extra strength, then it's unnecessary carried weight.
International 9200 (A63118)
International 9200...
SOUTHERN 3105-60" BOX BLADE (A62130)
SOUTHERN 3105-60"...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
PALLET OF SITE FENCE STABILIZERS (A62131)
PALLET OF SITE...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
