What size and thickness plastic pipe for 4x4 post?
   / What size and thickness plastic pipe for 4x4 post? #21
I’d use schedule 40 4” PVC and just shave your post corners a little. It would take 5 minutes with a circular saw or just use a sharp axe.
You can put PVC caps on the pipes when not in use to keep them clean and make them easier to find.
Just like this. ^
I have 4x4 removable volleyball posts in my back yard.
   / What size and thickness plastic pipe for 4x4 post? #22
I want to set a section of PVC or other type pipe in the ground and then be able to place a 4x4 post into the pipe.
vertically, or horizontally ?
my guess is vertically
   / What size and thickness plastic pipe for 4x4 post? #24
At our first house, we had a covered patio between the house and the garage. I wanted to put in a picket fence across one side, with a narrow gate, but wanted to be able to remove it as needed to bring larger things into the back door of the house. I found square steel tubing at a scrap yard that was 4” outside with .125” thickness. That makes 3.75” inside. A 4x4 is 3.5”. I buried the tubing and cemented it in. Built the fence in place, and it was easily removable.
IF you can find square tubing like that at a scrap yard, it’s worth it. New, it’s really expensive.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A57453)
1995 Chevrolet...
John Deere 5055E (A53317)
John Deere 5055E...
JCB 2145 (A47477)
JCB 2145 (A47477)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
ALLISON TRANSMISSION (A55745)
ALLISON...
