What size and thickness plastic pipe for 4x4 post?
   / What size and thickness plastic pipe for 4x4 post? #21
I’d use schedule 40 4” PVC and just shave your post corners a little. It would take 5 minutes with a circular saw or just use a sharp axe.
You can put PVC caps on the pipes when not in use to keep them clean and make them easier to find.
Just like this. ^
I have 4x4 removable volleyball posts in my back yard.
   / What size and thickness plastic pipe for 4x4 post? #22
I want to set a section of PVC or other type pipe in the ground and then be able to place a 4x4 post into the pipe.
vertically, or horizontally ?
my guess is vertically
   / What size and thickness plastic pipe for 4x4 post? #24
At our first house, we had a covered patio between the house and the garage. I wanted to put in a picket fence across one side, with a narrow gate, but wanted to be able to remove it as needed to bring larger things into the back door of the house. I found square steel tubing at a scrap yard that was 4” outside with .125” thickness. That makes 3.75” inside. A 4x4 is 3.5”. I buried the tubing and cemented it in. Built the fence in place, and it was easily removable.
IF you can find square tubing like that at a scrap yard, it’s worth it. New, it’s really expensive.
Ox Bodie 16x8 All Steel Dump Bed (A57453)
Ox Bodie 16x8 All...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2011 Peterbilt 365 Altec AC38-127S 5 Section 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Tr... (A56858)
2011 Peterbilt 365...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
