What size and thickness plastic pipe for 4x4 post?
   / What size and thickness plastic pipe for 4x4 post? #21
I’d use schedule 40 4” PVC and just shave your post corners a little. It would take 5 minutes with a circular saw or just use a sharp axe.
You can put PVC caps on the pipes when not in use to keep them clean and make them easier to find.
Just like this. ^
I have 4x4 removable volleyball posts in my back yard.
   / What size and thickness plastic pipe for 4x4 post? #22
I want to set a section of PVC or other type pipe in the ground and then be able to place a 4x4 post into the pipe.
vertically, or horizontally ?
my guess is vertically
   / What size and thickness plastic pipe for 4x4 post? #24
At our first house, we had a covered patio between the house and the garage. I wanted to put in a picket fence across one side, with a narrow gate, but wanted to be able to remove it as needed to bring larger things into the back door of the house. I found square steel tubing at a scrap yard that was 4” outside with .125” thickness. That makes 3.75” inside. A 4x4 is 3.5”. I buried the tubing and cemented it in. Built the fence in place, and it was easily removable.
IF you can find square tubing like that at a scrap yard, it’s worth it. New, it’s really expensive.
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
INOP/NON-RUNNING 1999 Chevrolet Express Bus, VIN # 1GBJG31R7X1137055 (A57453)
INOP/NON-RUNNING...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2024 8x22 Enclosed Trailer, VIN #7V0H12025RT420754 (A57453)
2024 8x22 Enclosed...
12ft 9in Altec Service Bed (A57453)
12ft 9in Altec...
