What rod is which?
/ What rod is which? #41
Yeah I hear you. I had a little buzz box once that burned 3/32 @ 120 amps.
I generally go by "ear". If it sounds like bacon cooking in the pan and it's not spattering too much it's good to go. I've learned that those guides posted on the welding machine(inside Mig Covers) are just that, General guides not specific.
I used an auto darkening hood a while back and felt blind. To each his own.
If you have a hard time seeing the puddle, try a reflective lense, it has helped me in the past.
Everybodies eyes are different. One person may need a 10 shade to mig while another may need an 11.
It isn't the perfect world. You make do with what you can. There is generally more than one way of doing something.
SMB
/ What rod is which? #43
what's everyone using for a poor fit rod on mild steel? 60k strenght is fine.. and penetration is not an issue, surface prep will be good.
Soundguy
/ What rod is which? #44
How poor of a fit?
7014 is fast fill fast freeze, but usually a 6011 will cut in and work in most situations. If you go with a 6013 and you end up tracking back across your slag (trying to join the poor fit) you can end up with problems, where the 6011 will cut through.
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
TARTER 180 CATTLE SWEEP (A64277)
TARTER 180 CATTLE...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
