Ballast What rear weights do you have?
   / What rear weights do you have? #22
<font color="blue">For those of you that are too lazy to make your own wheel weights</font>
I don't understand the 'too lazy' comment. /forums/images/graemlins/confused.gif Buying the exercise weights is the easy part. Building or buying the bracket is the hard part, particularly for those people who do not have access to a welder and the proper equipment to machine the steel.
<font color="blue">make your own wheel weights using barbells, check out this website: </font>
With EZ Weights you still have to use exercise weights. The EZ Weight people simply provide the bracket that bolts to the accessory holes on the wheel.
Since you are a new member, you might want to review the
Forum Rules and the Terms of Service.
   / What rear weights do you have? #23
Easy Mike, he might not have meant it with any malice, could be he just forgot the /forums/images/graemlins/tongue.gif or the /forums/images/graemlins/wink.gif
   / What rear weights do you have? #24
I use a 3 pt box on my 1500. That way it's easier to remove it and the FEL when I'm cutting the grass. Here's what I made out of some angle iron I had laying around. The weights and the rods they slide onto were picked up real cheap at a garage sale.
   / What rear weights do you have? #25
I have a BX2200 with turfs on it.
I have the rear wheel weights which weigh approximately 53 pounds each, I used them for a short while as they were included when i bought the tractor .
I later got the front Hydraulic angle blade (BX2763) and felt that I needed more weight for traction and got the 8160 BALLAST BOX and put 300 pounds of bag sand in it.
From what little I have used it , This for me was a Wise decision. Plenty of weight and so far have plowed in 2 wheel drive,plus if I ever do need a FEL I will have the appropiate counterweights.
   / What rear weights do you have? #26
I have bar tires filled with Rim-guard (beet juice) and today I mounted the Kubota weight box. When I sold my old tractor I gave the guy the weight box, but removed the weights... I had to find a place to put them, so I put all 500 of them into the Kubota box. I think that I have sufficient weight back there for any front end load... 506 bars X 1.25# = 632.5 lbs. Feels strange not having the backhoe on the tractor. /forums/images/graemlins/ooo.gif
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52141)
2018 HINO 268 NON...
