weeder
Time to change the oil in the 1705 Massey, a friend said to use shell T5 10w30 is that a good oil??
You're good to go. It's Diesel rated. Far better quality than when the Iseki 3 cylinder came out 40+ years ago. The GCs have been using the same basic engine for 25 years now. For a lot of winter use if stored unheated, may want to switch to a 0W or 5W oil.Well it is diesel tractor but the label said it is for diesel? I'm confused?
Wrong. They’re both diesel rated oils, intended for diesel engines. You can run either in a gasoline engine, if that’s what you wantIs it gas or diesel? T5 is fine for gas, T6 for diesel.
Wrong. Even the OP’s second post already stated he’s in physical possession of 10w-30 T5.I believe T5 only comes in 15-40 whereas T6 comes in 5-40.
Yes, it's fine.Well I have already bought some T5 10w30 is that ok?
