what oil do you guys use
/ what oil do you guys use #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Time to change the oil in the 1705 Massey, a friend said to use shell T5 10w30 is that a good oil??
Well I have already bought some T5 10w30 is that ok?
Is it gas or diesel? T5 is fine for gas, T6 for diesel.
Well it is diesel tractor but the label said it is for diesel? I'm confused?
/ what oil do you guys use #7
You're good to go. It's Diesel rated. Far better quality than when the Iseki 3 cylinder came out 40+ years ago. The GCs have been using the same basic engine for 25 years now. For a lot of winter use if stored unheated, may want to switch to a 0W or 5W oil.
Personally use Mobil Delvac 0W40. Its all about price and availability.
Ok thanks for the advice this tractor is always stored inside out of the weather especially in the cold never more than 40 degrees inside in the coldest months.
/ what oil do you guys use #9
I have used Shell Rotella T 10w-30 in my 2007 JD2520 for 18 years with no issues.
/ what oil do you guys use #14
OP- There is no product sold with more Marketing wonk than motor oil.... and criticizing ones choice is akin to calling your sister ugly. LOOK UP OIL PERFORMANCE DATA. It's out there. This site is bit of an echo chamber; many here are enamored with Rotella. Know that T5 consistantly outperforms T6. There are much better oils though.
Also, know that diesel oils are formulated to deal with the soot and filth of a diesel engine. In the test data you'll see they also test significantly lower in PSI shear and thermal breakdown than modern automotive motor oils. Gas engines run hotter and under higher stress than diesels... air cooled gas engine requirements are the worst! MANY sources say "never run diesel oil in a gas engine". Will it work? Many here will say they've done it for 100 years without issue. Just know that doing it leaves a very small factor of safety.
I run the diesel oil with the best test data available. If it's good enough for a $300k combine and excavator... it's good enough for my compact.
3 TON FLOOR JACK (A63569)
3 TON FLOOR JACK...
1762 (A58375)
1762 (A58375)
2022 EZ-GO ELITE...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
SHOP MADE 36' T/A GOOSENECK SHOWER/EYE WASHTRAILER (A63569)
SHOP MADE 36' T/A...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
