what oil do you guys use
   / what oil do you guys use #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Time to change the oil in the 1705 Massey, a friend said to use shell T5 10w30 is that a good oil??
Well I have already bought some T5 10w30 is that ok?
Is it gas or diesel? T5 is fine for gas, T6 for diesel.
Well it is diesel tractor but the label said it is for diesel? I'm confused?
   / what oil do you guys use #6
T5 is semi synthetic, T6 is full synthetic. I believe T5 only comes in 15-40 whereas T6 comes in 5-40.
   / what oil do you guys use #7
You're good to go. It's Diesel rated. Far better quality than when the Iseki 3 cylinder came out 40+ years ago. The GCs have been using the same basic engine for 25 years now. For a lot of winter use if stored unheated, may want to switch to a 0W or 5W oil.
Personally use Mobil Delvac 0W40. Its all about price and availability.
Ok thanks for the advice this tractor is always stored inside out of the weather especially in the cold never more than 40 degrees inside in the coldest months.
   / what oil do you guys use #9
I have used Shell Rotella T 10w-30 in my 2007 JD2520 for 18 years with no issues.
   / what oil do you guys use #10
Wrong. They’re both diesel rated oils, intended for diesel engines. You can run either in a gasoline engine, if that’s what you want
HOMELITE LEAF BLOWER (A48992)
HOMELITE LEAF...
Lyom-053 Unassembled Safety Basket Forklift Attachment (A46683)
Lyom-053...
2014 ISUZU NPR 16FT STAKE BED (A50046)
2014 ISUZU NPR...
Kobelco Excavator SK160LC (A48837)
Kobelco Excavator...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2019 CATERPILLAR 313FL EXCAVATOR (A50458)
2019 CATERPILLAR...
