what model's to consider?
/ what model's to consider?
Good luck on whatver tractor you get.
one thing though.. i see you mentioned pushing dirt... keep in mind that box blades pull dirt great.. but you have to be carefull pushing dirt... a scut / cut and a rear blade is not a bull dozer. Those drag links are great in tension.. not so great under compression.. looking at the geometry.. etc..
soundguy
I agree... I will probably be scraping an inch at a time with the box blade and then removing the spoils with the FEL.
I bought the Kubota L2800 HST w/FEL today. :)
/ what model's to consider? #22
Loaders are great for moving the stock piles after you scratch them up..
soundguy
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 BX2680 Sub Compact Utility Tractor (A63118)
2017 BX2680 Sub...
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
