What loader?
/ What loader? #1
hribal28wv
Ford/nh 1920 4x4
Hi, new to the site recently purchased a ford/nh 1920 4x4. I found a 7209 loader could anyone tell me if i am able to make that work? Not a whole lot of info out
there
/ What loader? #2
Good Morning there hribal28wv. I looked around the internet and "it says" you should be able to get the 7209 to fit your Ford. The info I was unable to find - what, if any, gymnastics you might have to go thru to make this fit.
I suggest - contact your local Ford dealer and see what they can offer.
BTW - welcome to TBN.
/ What loader? #3
The 7209 was used on the 2120 and the 3 cylinder 2810-4610 tractors. Different mounts were made for the different models.
7108 or 7308 was fitted to the 1920.
I believe the 7209 was used on the 2120 as it had a higher load rating necessary on the 2120.
I don't think there is any reason that you couldn't put it on a 1920 other than there was no mount for a 1920.
/ What loader?
Talked to long lane and they said thought it would be too big. Thanks for your info
/ What loader?
Long lane tractors said it was too big but idk lol. It sold already so I found a nh 110tl on a tractor that caught fire but minimal loafer damage does anyone have a pic of how their hydraulic lines hook up the lines hook up from the control valve to the (fitting block or valve?) Or whatever that is on the bottom of the tractor
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
iDrive TDS-2010H...
Brown 6' Tree Cutter (A64119)
Brown 6' Tree...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
8ft Fork Extensions (A61572)
8ft Fork...
