What liquid expands the most with a temperature change?
   / What liquid expands the most with a temperature change? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I can't go into the details of the project but basically I intend to fill the bottom side only of a "hydraulic" cylinder with a yet to be determined fluid. What is going to provide the most movement of the cylinder with a temperature change? Just looking at a couple of charts that I have no idea what they actually mean maybe Ammonia.
   / What liquid expands the most with a temperature change? #2
There are more complications to this than appears on the surface. Ammonia is nasty to work with and needs to be under a high pressure to remain liquid. Any gas off the liquid will be compressible so will not move the push rod. The seals on a hydro cylinder will probably not be compatible with a lot of fluids, especially like ammonia. Think Teflon seals. A lot of research on temp/press relationships and hydro calcs are in your toolbox for this. You will be dealing with more than one liquid/gas physics laws. My arm chair engineering at work.
Ron
I've already thought about at least the corrosive part. The possible solution was to use an expansion tank. Put the expanding liquid in the rubber bladder and put put oil in the other side. Then it expands and forces oil out of the cylinder into the tank.
   / What liquid expands the most with a temperature change? #4
I suppose a pertinent question is what are you trying to accomplish? Detect a temperature change? Move something heavy (or light) based on temperature? Something else?
Have you ruled out electronic sensors and actuators?
I'm trying to move something light based upon a temperature change. Electric isn't an option.
   / What liquid expands the most with a temperature change? #6
Remember that many liquids don't expand at a regular rate. That is, they don't expand proportionally to temperature changes. Mercury in a thermometer expands very regularly through a broad temperature change. So keep that in mind for your project X.
Also, you can't compress a liquid, so if its under pressure, it won't move much. Release the pressure and woosh!
   / What liquid expands the most with a temperature change? #7
Have you thought about using metal like a thermostat?
I probably need 10 pounds of push and 3 inches of travel. I don't think the metal could accomplish it.
   / What liquid expands the most with a temperature change? #9
I hope you share the project once its done.... sounds interesting. :thumbsup:
   / What liquid expands the most with a temperature change? #10
Greenhouse vent cylinders.
Automatic Greenhouse Vent Openers & Circulation Fans
How automatic vent openers work: Vent openers do not require electricity. The opener has a metal cylinder containing a mineral which expands when heated. This pushes a piston that opens the vent. As the temperature cools, the mineral shrinks and a spring closes the vent and resets the piston. The opening and closing of the vent is gradual allowing just the right amount of air flow for cooling.
and
Greenhouse Accessories : Univent Automatic Vent Opener Replacement Cylinder
Use the Standard Vent Opener to lift up to 15 lbs, and the much stronger Gigavent, with powder-coated green, all metal construction, to lift up to 65 lbs.
Bruce
That's pretty much what I'm trying to accomplish but I need it to close at a lower temperature. Since other similar devices exist I might as well spill the beans since I'm not going to get rich. I'm trying to activate a water shutoff valve when it gets below freezing. I'm hoping to use no electric before most of the other versions do use electric and I'm hoping that with spring assistance it will turn the water back on when it warms up.
   / What liquid expands the most with a temperature change? #12
Use water then. It expands when frozen and will contract at room temp from frozen size. Make your own cylinder out of some plastic pipe. Test random sizes, I would start small diameter so it would freeze before valve. Like tow sizes of pex ? Or maybe even a rubber diaphragm with some sort of gas in it? You could pull the valve instead of push it?
   / What liquid expands the most with a temperature change? #13
By that point my water lines are already frozen.
   / What liquid expands the most with a temperature change? #15
Salt expands quite extreme, but it turns liquid only after 450 degrees Celsius or so.
What do you need it for, a Stirling engine ?
   / What liquid expands the most with a temperature change? #16
and
Bruce
They also use a linkage that multiplies a small movement into a longer stroke. There is an engineering principle there.
Ron
   / What liquid expands the most with a temperature change? #17
Quarter turn water valves take more pressure than you may realize so size your cylinder commensurate with that issue.
Ron
Ron
I actually need to turn off a frost free hydrant because it's the only water source I have and it'll freeze if it's open.
They take more power to open and close. This project may turn into something more trouble than it's worth.
Ron
Likely so but I enjoy a challenge. After I posted this thread I've found a valve that Ts into the water line and opens once the water reaches 35 degrees. That solves 2 possible 3 of the 4 hurdles in this project. The next issue is if I use that approach how do I turn the water back on?
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
