What is Your Off Road -Ranch - Farm Utility Trailer
   / What is Your Off Road -Ranch - Farm Utility Trailer #21
Wow like whole concept in picture, trailer and "rock" basket....
Dale
It is pretty handy only having to handle the rocks by hand once. I have either 6 or 8 of those half barrels. I load them through the summer then borrow my brothers dump trailer to haul them away or put them on my equipment trailer to haul away as shown.
   / What is Your Off Road -Ranch - Farm Utility Trailer #22
You guys have posted some really nice trailers!!!!
Did anyone read his original post in which he described his tractor? :D
   / What is Your Off Road -Ranch - Farm Utility Trailer #23
What did you do for the hydraulics? What size cylinder and how did you figure the geometry? I have a wagon from them as well, really like it, especially the 4 wheels so it can be detached easily.
Their site specs the cylinder as a 24" stroke up to 4" bore (i used 2" bore). I bought a self contained pump/reservoir unit off amazon, deep cycle battery, custom hoses and adapter fittings from TSC. Probably had $300-350 in the hydraulics worst case. I can go a couple days cycling the pump under a heavy load 6-8 times per day with no battery issues. Never ran the battery down. Lastly i fabbed the battery and pump unit brackets from steel angle and flat stock.
   / What is Your Off Road -Ranch - Farm Utility Trailer #24
Sure did. I posted my picture so he could get an idea of designing and building his own but then I saw where he didn't want to build his own.
   / What is Your Off Road -Ranch - Farm Utility Trailer #25
I guess your right. I just saw the 25 hp part. Just now looked up his tractor specs - not enough size and weight to pull much.
gg
   / What is Your Off Road -Ranch - Farm Utility Trailer #26
Reb and Gordon,,, we got to see some really cool trailers and wagons though!!!! :D
   / What is Your Off Road -Ranch - Farm Utility Trailer #27
Yes and mine will work but to much money for him...:)
   / What is Your Off Road -Ranch - Farm Utility Trailer #28
   / What is Your Off Road -Ranch - Farm Utility Trailer #29
Other option might be one of the <$500 trailers from harbor freight - and then adding a sheet of plywood for a bed, and wood sidewalls if/when needed.
Not a whole lot of ready made options between ATV and larger road/agriculture trailers.
Otherwise the closest things I've seen are (beyond the previously mentioned) would be an EZ Trail compact wagon, a dump trailer by Berkelmans Welding & Manufacturing...
Though given the size of tractor an ATV trailer would probably have more than enough load carrying capacity (gravel can weight 1.5-2 tons per yard).... which means some of those ATV trailers may very well be able to carry more than can be easily stopped by a SCUT even if they don't have the desired volume with sidewalls raised/in place.
   / What is Your Off Road -Ranch - Farm Utility Trailer #30
This is my farm wagon. I purchased brand new Horst 10-ton running gear about eight years ago. I found a DIY web site and built the box. It's bigger than you need but Horst has all sizes. If you are into a DIY project.
View attachment 646317View attachment 646318
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
Toolbox (A51573)
Toolbox (A51573)
