What is user UNFRIENDLY on your tractor?
   / What is user UNFRIENDLY on your tractor? #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I like my Massey 1758 tractor. But I have to nominate how to change the dashboard display from Km/Hr to Miles per Hour as one of the most user UNFRIENDLY things I've seen on a tractor.
Here are the steps to changes from Km/Hr to Miles per Hour on my 1758:
1) Turn ignition key off and leave it off for at least 1 minute.
2) Remove the fuse cover below the steering wheel. Remove the 5 amp bottom right hand side fuse.
3) Turn the ignition key switch on but do not start the engine.
4) Press the "Display Select Switch" on the dash one time.
5) Begin pressing this same switch enough times until you see "Unit Set" on the display.
6) Long press the "Display Select switch" for 2 seconds until you hear the Buzzer go off and release.
7) Wait about 2 seconds for the Display to say "Unit Set"
8) Turn the ignition switch off.
9) Re-install the fuse.
Presto! In just 9 easy steps (plus a fuse pull) it now reads miles per hour instead of Km/hr.
Does your tractor have something you would also consider to be user unfriendly?
   / What is user UNFRIENDLY on your tractor? #2
Well I really don't like where the dash mounted throttle is on my tractor. I've considered moving it to beside the seat Where John Deere should have put it. My problem is relatively minor compared to changing units on your tractor. ( Said with a grin on my face. )
   / What is user UNFRIENDLY on your tractor? #3
Completing tractor/implement PTO connection.
   / What is user UNFRIENDLY on your tractor? #4
Cup holder is too large diameter so a water bottle not held snugly. Also too shallow so water bottle bounces out.
Oh also open station and no ac for these 100 degree days.
   / What is user UNFRIENDLY on your tractor? #5
Kubota not spending the huge sums it would have taken to put a grab handle on the right fender. They sell them and the mount holes are there, you just have to order in one for $80 or whatever it is. Cheapening out on a handle on a thousands of dollar tractor. It's like not putting an armrest in a car but you can buy one as an addon.
There, now I feel better.
   / What is user UNFRIENDLY on your tractor? #6
I have grab handles just above each fender, but an extra grab handle near the dash would keep me from grabbing the steering wheel. There's plenty of room for one.
Also, NO PLACE TO PUT A CELL PHONE.
Also, all tractors should come with, or have as an option, a toolbox, or at least a handy mount for one.
(Otherwise love it. :) )
   / What is user UNFRIENDLY on your tractor? #7
Don't know if this fits, but on my Kubota the split breaks and the floor peddle are on the same side, my right foot can't be in two places at the same time. How is this supposed to work ?
It's a B2920..
   / What is user UNFRIENDLY on your tractor? #8
It's a B2920..
You know, I was wondering about that. Not being a salty veteran with tractors, I haven't had a reason to use just one side of the brakes but thought to myself that'd be pretty hard to do even if I wanted to. Maybe you're supposed to ride side saddle in those situations :laughing:
   / What is user UNFRIENDLY on your tractor? #9
I know, unless your supposed to use the cruise control, but still...Kubota, what were you thinking ?? I should ask them..
   / What is user UNFRIENDLY on your tractor? #10
I sent in the last three post, we'll see if they respond..
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
(INOP) EZ GO GAS GOLF CART (A57192)
(INOP) EZ GO GAS...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A57192)
UNUSED IRANCH...
NEW HOLLAND TS6.120 TRACTOR (A57192)
NEW HOLLAND...
