What is this?
/ What is this? #1
Poopdeck Pappy
Elite Member
Dallas, Texas
Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
I was in the DK50SE cab the other day and noticed this laying beside the seat on the left side. I looked but could not figure out where it went or what it is. Any thoughts?
/ What is this? #2
Coffee Cup?
/ What is this? #3
It is your PTO cover/cap. Threaded bolt goes on top....
/ What is this?
Well dang. I thought it fell off inside the cab. Never would have figured out it was a PTO cover. Thanks. Now I can throw it in the parts bin and it will likely never be seen again. Thanks. :ashamed:
/ What is this? #5
The same thing happened to me. It was stuck beside the seat. I could not figure out where it came from, until I stopped by a dealer. One of his new tractors still had it on the rear PTO. I could not tell you where mine is now. Somewhere in the shop, maybe.
/ What is this? #6
I actually use mine. When I mount something to the PTO, I put it in the "toolbox" behind the seat.
Since the OEM "toolbox" is full when the cover is stored in it, I think the box could more acurately be called a PTO Cover Cover.
/ What is this? #7
I did not have one on mine.
/ What is this? #8
I doubt it is mission-critical, but I did notice the one time that I did not use it, I had to brush away a bunch of trash before I mounted my bushhog to the PTO. Since then I have been using it and the PTO shaft stays clean for when I want to use it.
/ What is this? #9
350 hours and mine is still on the pto right where MIE put it when it was new. I hope the pto works!!! CJ
/ What is this? #10
I still use mine too. In colder weather, if I don't have the blower on the back, I will turn the PTO on as part of my warm up time to get the hydraulic oil flowing and warming while the tractor is sitting at an idle. I leave the cover on just in case. Not that they'd go anywhere near the tractor, especially when it's running, but 3 small kids around means I do whatever I can to keep things safe.
/ What is this? #11
Good grief, I took that thing off the day I got my tractor in 2008 and it is floating around in the shop someplace. I see no reason to cover the pto shaft:confused3:
/ What is this? #12
When I bought my current tractor it had 1972 hours on it and the PTO cap was still on it. The tractor had been used for boxblading pretty much its entire life. By the looks of the PTO shaft I don't think it had ever had anything on it. I took the cap off the first time I needed to use the bush hog. I threw it in the recycle barrel when I took it off.
/ What is this? #13
I guess the PO has (or lost) the cover that came with my Kioti. Not a problem so far because I always have a mower or a bush hog on the PTO shaft. But I can see the value of a cover (to keep dirt out of the grease) if I was dragging a blade/box blade or disks.
/ What is this? #15
I leave my cover on for safety too. Here's why:
A friend of mine had a buddy riding on the back of his old tractor a few years ago. They were moving some logs out of a woods trail and the guy's jeans got snagged up by the revolving rear PTO... in an instant, his foot was ripped off above the ankle.
Those covers serve a purpose, sometimes forgiving improper operation of the tractor.
/ What is this? #16
I had one and used it for the first 500 hours. About to hit 900 and have not seen it for a while. Not real worried about it.
Scott
/ What is this?
I removed the mower and put the new (to me) box blade on yesterday. I put the PTO cover on. Figured it would help keep it clean. I've never seen one before, but in retrospect it's a good idea and I'm glad I've got it.
Thanks for the info on what it was. I thought it was something that had fallen off in the cab.
/ What is this? #18
I have to ask..why was it engaged and spinning?
/ What is this? #19
.... that is the same question the operator of the tractor has to revisit every day for the rest of his life. Chalk it up to human error.
121A (A63745)
121A (A63745)
(2) STAINLESS STEEL HOG FEEDERS (A64278)
(2) STAINLESS...
Amco 3-Pt Rotary Ditcher (A66408)
Amco 3-Pt Rotary...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
