Oil & Fuel What is this indicator for? YM2820D
   / What is this indicator for? YM2820D #11
That warning light has to be wired to a sender somewhere on the transmission, or ???
I looked all around underneath and did not find anything, so then I pulled the plastic cover off from over the trans below the instrument panel and found a connector with some wires running towards the back underneath the seat panel. Before I pull the instrument panel again (had it off before to check for any hack wiring job and to clean out the hay/mice nests the other day) I may just wait to see what kind of wiring diagrams are in the manuals when they get here. If there is no other place to check oil levels I guess I am safe to use it?
   / What is this indicator for? YM2820D #13
Good question. Not sure if the indicator also tells the condition of the oil or hydraulic pump. So, it's not all that easy to define safe.
UNUSED FUTURE EQUIPMENT SEAT (A58376)
UNUSED FUTURE...
7ft Metal Gulf Gas Pump (A57454)
7ft Metal Gulf Gas...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58216)
2012 TEX MEX...
Ford 3000 (A57148)
Ford 3000 (A57148)
John Deere Metal Truck (A57454)
John Deere Metal...
2024 Kubota MX5400 (A57148)
2024 Kubota MX5400...
