What is this fitting called?
/ What is this fitting called? #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
The hydraulic return line on my tractor (Jinma 354) has kind of an odd fitting. There is a hard line with a banjo fitting, but instead of a banjo bolt there is a hose with a threaded male fitting screwed into the side of the banjo. Here is a picture of the hose:
I'm just wondering what the fitting on the end of the hose is called.
Thanks.
/ What is this fitting called? #2
Looks like a bulkhead fitting. Designed to go through a late or bracket and be securely retained by a jam nut and whatever fitting goes on the end.
/ What is this fitting called? #3
Male Pipe x JIC 37° Bulkhead union fitting.
/ What is this fitting called? #4
Thanks for the quick responses. You can barely see it in the picture, but the pipe end is drilled through sideways like a banjo bolt. Does that change the answer?
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED AGT MX-MRT14 STAND-ON SKID STEER (A64280)
UNUSED AGT...
(2) UNUSED 11.2-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 11.2-24...
2016 Sky Jack SJ8831RT 31ft 4x4 Rough Terrain Scissor Lift (A61572)
2016 Sky Jack...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
