What is this fitting called?
/ What is this fitting called? #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
The hydraulic return line on my tractor (Jinma 354) has kind of an odd fitting. There is a hard line with a banjo fitting, but instead of a banjo bolt there is a hose with a threaded male fitting screwed into the side of the banjo. Here is a picture of the hose:
I'm just wondering what the fitting on the end of the hose is called.
Thanks.
/ What is this fitting called? #2
Looks like a bulkhead fitting. Designed to go through a late or bracket and be securely retained by a jam nut and whatever fitting goes on the end.
/ What is this fitting called? #3
Male Pipe x JIC 37° Bulkhead union fitting.
/ What is this fitting called? #4
Thanks for the quick responses. You can barely see it in the picture, but the pipe end is drilled through sideways like a banjo bolt. Does that change the answer?
