What is this bearing?
   / What is this bearing?
WOW!
Totally not what I expected to see after looking at the remains of that bearing!
I can't see how even a dropped bearing from the factory could be that damaged and not have something else destroyed in the process.
At this point one would have to wonder if it wasn't done on purpose just to freak someone (me) out?
In any case, it looks like you have no damage and I see no reason not to clean out the crap and refill with fresh oil, then forgetaboutit.
Lucky you. Except for the scare part....
Yep, the only evidence of damage is to that metal under the bolts on the pinion ring gear. hopefully its just two days of learning and discovering and its the end of it. I am baffled as to how the bearing could fall off the end of a shaft because there are no shaft "ends" that I can see.
   / What is this bearing? #22
I saw 6205 and 6305 bearings up there.
   / What is this bearing? #23
That's a nasty surprise on the magnet, and your analysis of the bearing is spot on. That's definitely the remains of a deep groove ball bearing.
Here is the structural diagram of the deep groove ball bearing.
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
2025 GPS Trailers MDR2014K 24ft. 7 Ton T/A Dovetail Equipment Trailer (A56858)
2025 GPS Trailers...
2876 (A58376)
2876 (A58376)
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
