What is the phenomenon called...
   / What is the phenomenon called... #51
My FEL will easily lift the rear tires off the ground with BH on.
I can see that happen if there is something under the FEL but it would have to be pretty tall.
I took some video today piling up limbs the recent snow knocked down. I was tamping the limbs down to compress them and noticed in the video that had I raised the front end much higher I would have rocked back on the bottom of the BH which could lift the rear wheels by changing the pivot point from the axle to the BH. Not something I want to experience. I think I will stop compressing the burn pile quite so aggressively in the future.
I think it’s the same principle as drag cars using wheelie bars. Rock back on the rear bumper and the rear wheels will lift enough to lose contact with the ground
   / What is the phenomenon called... #52
Do you mean pushing down with the loader or lifting up and pivoting over the front axle?
   / What is the phenomenon called... #53
Pivoting over the front axle trying to lift something too heavy... did it a few times when my BX was new and I was trying to dislodge logs from a debris pile that was made by an excavator. I was facing downhill. On flat ground using my forks trying to lift too heavy a pallet, this doesn't happen... it limits out.
   / What is the phenomenon called... #54
Could you lift both back wheels or just one?
   / What is the phenomenon called... #55
Well one completely and the other was very close. I didn't push it. :shocked:
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2020 DRAGON ESP...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
