Case International 1255xl
   / Case International 1255xl
Thanks crush for that info, do you know if a 1455xl engine would fit in a 1255xl tractor, just know of another 1255xl its the older type one, think its 1983, engine not good with bits missing
   / Case International 1255xl #12
Should fit o/k I would think!!, only problem might be the air cleaner assy, 1255 might have a smaller one ??,you need to check parts books to be sure!!
Bonnet & side panels should be same , check engine block is same length??, if it is longer? On 1455 then the prop shaft may need changing??
Otherwise,o/k.
ok is there any difference (apart from the colours and front section) between the old 1255xl and the newer 1255xl
14C SCRAPER (A58214)
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
1111-A (A54756)
1111-A (A54756)
