What is the phenomenon called...
   / What is the phenomenon called... #51
My FEL will easily lift the rear tires off the ground with BH on.
I can see that happen if there is something under the FEL but it would have to be pretty tall.
I took some video today piling up limbs the recent snow knocked down. I was tamping the limbs down to compress them and noticed in the video that had I raised the front end much higher I would have rocked back on the bottom of the BH which could lift the rear wheels by changing the pivot point from the axle to the BH. Not something I want to experience. I think I will stop compressing the burn pile quite so aggressively in the future.
I think it’s the same principle as drag cars using wheelie bars. Rock back on the rear bumper and the rear wheels will lift enough to lose contact with the ground
   / What is the phenomenon called... #52
Do you mean pushing down with the loader or lifting up and pivoting over the front axle?
   / What is the phenomenon called... #53
Pivoting over the front axle trying to lift something too heavy... did it a few times when my BX was new and I was trying to dislodge logs from a debris pile that was made by an excavator. I was facing downhill. On flat ground using my forks trying to lift too heavy a pallet, this doesn't happen... it limits out.
   / What is the phenomenon called... #54
Could you lift both back wheels or just one?
   / What is the phenomenon called... #55
Well one completely and the other was very close. I didn't push it. :shocked:
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
MASSAGE CHAIR (A58214)
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
