what is the difference between these gearbox's?
   / what is the difference between these gearbox's? #2
the one says includes the splined bushing (the one with label on the box in the picture),
I do not know, but the boxes look slighly diffrnet in shape, but the spec. seem to be the same, possibly the manufacturer?
   / what is the difference between these gearbox's? #3
One has a splined input shaft, the other is either keyed or just uses a shear bolt..
   / what is the difference between these gearbox's? #4
They look to be the same but you get the splined bushing for the stump jumper with the one and not with the other. Since both are the same price, I would get the one with the stump jumper bushing. My brother in law had one of those break on his 4 footer and I had to V everything out and reweld. You could even sell the bushing to someone building his own shredder for a few bucks profit.
   / what is the difference between these gearbox's? #5
One of them is in stock in most stores,the other isn't.
   / what is the difference between these gearbox's? #6
The first one says 12 spline input shaft and the second one says 6-Spline input shaft.
ahh thanks, nice. is this were the pto connects , or the blades?
   / what is the difference between these gearbox's? #8
•Output shaft 1-1/2" - 12 spline input shaft - 1-3/8" splined
my guess is it is a typo, and should be, •Output shaft 1-1/2" - 12 spline, Input shaft - 1-3/8" splined
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
Kubota Z232 (A60462)
2008 GENIE S-65 TELESCOPIC BOOM LIFT (A60429)
2008 GENIE S-65...
CAT D8 (A58214)
CAT D8 (A58214)
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
