What is the difference between B3030, B7800, B2910
   / What is the difference between B3030, B7800, B2910 #11
There are some other added items on B3030.
Rear hydraulic output.
Cup holder.
Seat arm rest. I sat on a fellow TBNer's <font color="blue"> NH </font>a few day ago. No arm rest. It's the first thing I noticed beside his tractor was larger than mine.
   / What is the difference between B3030, B7800, B2910 #12
A question springs to mind. How does Position Control figure in if you get Top and Tilt for the 3PH? I was thinking that I would add TnT to the B3030 I want to get.
   / What is the difference between B3030, B7800, B2910 #13
Even though the mid-point PTO is offset on the B3030? I was also reading that the FEL controls remain with the tractor when you remove the FEL. Is that the way it is on the B2910 also?
   / What is the difference between B3030, B7800, B2910 #14
Position control adds more adjust to the attachment being used. Tip will add side to side adjustment, Top will add the ability to change length of top link. Both of these adjustments may require the position control stop to be set at a different position.
   / What is the difference between B3030, B7800, B2910 #15
<font color="blue"> FEL controls remain with the tractor when you remove the FEL. </font>
402 FEL controls remain on tractor also.
   / What is the difference between B3030, B7800, B2910 #16
</font><font color="blue" class="small">( The B3030....you can get a cab version of the tractor.)</font>
Rolando answered a question for me recently re. the B3030, but didn't point it out here: the B3030 can have a cab, or a backhoe, but not both.
</font><font color="blue" class="small">( $2281 list price also gets you:
Lever type cruise control feature,
Tilt and Telescopic steering wheel,
Softgrip steering wheel,
Adjustable seat suspension,
Extendible lower links on the three point hitch,
Ratchet type right link adjusting on the three point hitch,
Mid PTO as standard equipment. )</font>
Hmmm. I know I need the Mid-PTO, and the valving seems like a nice feature, but does anyone know what these two separate upgrades on the B7800 would be? I think the mid PTO on an L series is about $400. Also, does the offset mid PTO affect the number of front implements I can use?
   / What is the difference between B3030, B7800, B2910 #18
</font><font color="blue" class="small">( I know I need the Mid-PTO, and the valving seems like a nice feature, but does anyone know what these two separate upgrades on the B7800 would be? )</font>
For about $300 more than the basic model you get a B7800 with mid-PTO and folding ROPS.
I find the quarter inching valve is easy and precise, although there is some sag in the 3PH which varies by the weight of the implement, how rough the terrain, etc. To the best of my knowledge, there is no economical upgrade to position control.
Another difference is the B7800 has a cheesy turnbuckle style "check chain" on the 3PH lower arms. Mine failed after about 130 hours of use. I replaced those with the B2910 bracket and pipe stabilizers for about $140 in parts from tractorsmart.com.
For me, the B7800 is the right machine. I sometimes wish for a heavier machine, and sometimes for smaller, but never for a more expensive or luxurious one.
   / What is the difference between B3030, B7800, B2910 #19
<font color="blue"> $2281 list price also gets you: </font>
The price difference is not that great when all options are considered.
It's less than $1900. Still a lot of money. There are many items that make the B7800 cheaper than the B3030 that is not in the literature. Visiting a dealer to compare them is about the only way to see the difference.
I looked through all your post. I do not see what your previous experience is with tractors. I do see where you were looking at the L**30 series tractors. The B3030 and B2910 have most of the features that the L**30s do. If you are not experienced with attaching 3PH attachments, I would suggest that you make sure that you know what you are giving up before you decide that the premium features of the B2910 and B3030 are not worth the extra money.
I have changed FEL and 3PH attachments several times a day. The chain stabilizers for lower links are pain to adjust for removing and installing attachments. Telescopic lower link ends make it much easier to line up heavy 3PH attachments.
There is no offset PTO that I have found in B2910 or B3030 literature. I have removed and installed my MMM many times. The easiest part is hooking up the Mid PTO from rear of tractor.
Please take the time to check out all the features that the premium tractors offer. In the end you may end up with a B7800. At least you will know what you gave up for $1900.
   / What is the difference between B3030, B7800, B2910 #20
If you look in the Deen Implement web site, on the B2630/B3030 page, about half-way down, is the following statement:
"Offset mid-PTO
Being offset to the side, quick installation and removal of the mower is now possible."
I'm assuming they got this from the yet-to-be-seen Kubota brochure. Can the dealers that have seen the actual tractor confirm?
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
John Deere 693 Corn Head (A50514)
John Deere 693...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
2020 KUBOTA RTV...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
