What is blowby?
/ What is blowby? #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
When someone says that a diesel has excessive blowby, what exactly does that mean? Is it a generic term for a symptom which may have any of several causes? Is it a technical term that everyone whould agree on, or is it open to interpretation?
Thanks,
Cliff
/ What is blowby?
Thanks,
Cliff
/ What is blowby? #3
It usually refers to excessively worn piston rings thereby allowing air and fuel to "blow by" the rings into the crankcase.
/ What is blowby? #4
/ What is blowby? #5
Blowby is compression from the combustion chamber(s) leaking into the lubrication system. It can be caused by other things (such as an ususal blown head gasket, hole in piston, etc.) but is typically caused worn or broken rings, as stated...
/ What is blowby? #6
/ What is blowby? #7
As stated it is compression being released from the internal part of the engine. But where you see blowby is usually from a tube off of the valve cover. It will run down the side of the engine and you will see a puff of air, smoke, oil on each piston compression stroke. Of course the tube could be missing. All engines can have some blowby. It is excessive to see oil misting, large amounts of smoke, strong air flow, you get the idea.
/ What is blowby? #8
/ What is blowby? #9
blowby = slang
Man did that dude blowby me in that corvette. /forums/images/graemlins/grin.gif
/ What is blowby? #10
blowby = slang
/ What is blowby?
Thanks everyone for describing it in a way that didn't blowby me. Makes sense.
Cliff
/ What is blowby?
Cliff
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2024 John Deere 6130M Tractor Loader (A63109)
2024 John Deere...
1990 CASE 580K LOADER BACKHOE (A64047)
1990 CASE 580K...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
