Quick Hitches what is best conversion device
/ what is best conversion device #1
redsky47
longmont, co
kioti 3054
Have a class 1 tractor (Kioti 3054) and just bought a used class 2 sickle cutter which has 1 1/8' pins. What is recommended to convert? Was looking at Pat's device - are the hooks on the class one version large enough to support 1 1/8" pins? Any other recommendations?
/ what is best conversion device #2
Welcome! Are the pins on your sickle mower bolts or are they welded on?
Easiest thing to do is replace the pins to Cat 1.
Tractor Supply and most any similar type store (Agri Supply, Rural King, etc.) has replacement pins.
Unbolt yours from your mower, bring them with you, get the same bolt size as you have but in a Cat 1 pin size.
Example linked.
CountyLine® Draw Pin, Cat 1, S070202TSC - Tractor Supply Online Store
/ what is best conversion device #3
Ditto what dusty3030 said
But you may also have to turn the pins inward, as cat II spacing is 32" and not all cat I tractors lower arms open wide enough as cat I is 26".
So instead of pins facing outward, they just face inward, and is a bit different to hook up, but doable.
unfortunately pins are welded on...bolts would have been too easy! Even so, replacing the pins may still be the best option as both of you have suggested. Thanks for the advice.
/ what is best conversion device #5
Could you post a picture of the current pins on the mower?
/ what is best conversion device #6
Yep, unfortunately, replacing the pins is about the only way to go.
If it was going from a cat I mower to a cat II tractor, $5 worth of bushing would have been all that was needed.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
2021 JOHN DEERE 317G SKID STEER (A65056)
2021 JOHN DEERE...
2023 JCB 90Z-2 T4 Midi Excavator (A66734)
2023 JCB 90Z-2 T4...
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
