What is “tripping” my electrical system (requires 40amp fuse pull to reset)
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #1
oldwash
Kubota L2800
L2800. I was having safety switch issues prior, but would just click and not start. This is a loud click and kills all power. I just installed a hard start kit with no luck. Any idea what would kill the whole system requiring me to pull the main fuse to reset (does not melt the fuse)?
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #2
Maybe the starter is worn out?
What yr and hrs is the tractor?
Is the battery fresh or is it drawing down on starting?
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #3
Guessing is taking the long road to the solution,use an amp meter to find what's pulling high amps. Taking note of what is in operation at and just prior to failure can give hint to culprit.
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #4
Yeah, one wonders if the starter is frozen.
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #5
I had that happen on my kioti. Turned out to be defective positive battery cable. Ohm out cables, and make sure you cant manually twist the battery cables on battery post. My cable rotted under the plastic sheath.
2012 LAND ROVER Range Rover SUV (A56859)
2012 LAND ROVER...
BLUEHAWK 17CU FT STEEL LAWN MOWER TRAILER (A58374)
BLUEHAWK 17CU FT...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2016 CATERPILLAR 415F2 BACKHOE (A52709)
2016 CATERPILLAR...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
