What is “tripping” my electrical system (requires 40amp fuse pull to reset)
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #1
oldwash
Kubota L2800
L2800. I was having safety switch issues prior, but would just click and not start. This is a loud click and kills all power. I just installed a hard start kit with no luck. Any idea what would kill the whole system requiring me to pull the main fuse to reset (does not melt the fuse)?
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #2
Maybe the starter is worn out?
What yr and hrs is the tractor?
Is the battery fresh or is it drawing down on starting?
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #3
Guessing is taking the long road to the solution,use an amp meter to find what's pulling high amps. Taking note of what is in operation at and just prior to failure can give hint to culprit.
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #4
Yeah, one wonders if the starter is frozen.
   / What is “tripping” my electrical system (requires 40amp fuse pull to reset) #5
I had that happen on my kioti. Turned out to be defective positive battery cable. Ohm out cables, and make sure you cant manually twist the battery cables on battery post. My cable rotted under the plastic sheath.
2008 STEPHENS CRUDE TRAILER (A55745)
2008 STEPHENS...
11' CONTAINER (A52706)
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A55851)
1999 Toro...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
