What implements do y'all have for food plots, and what do you wish you had?
   / What implements do y'all have for food plots, and what do you wish you had? #21
Nice harvest.
Just curious, how does a cultipacker control the depth of the smaller seeds? I have never used one and am looking for a dependable method to plant clover and other brassicas out.
I get the ground worked up pretty good with a disk and drag. Here in upstate NY, I start my clover plots/wheat plots after September 1, on ground where I had corn the year prior.
To plant that “mix”, I broadcast wheat first, with a hand cranked broadcast spreader. Then I cultipack, which pushes the larger wheat seeds about 1/2” into the fluffy, fresh worked soil. Sometimes I’ll broadcast a some soybeans or awp along with the wheat, prior to that initial cultipack.
Those are also larger seeds that grow best when planted about 1/2” deep. They provide an early “sweetener” to the plots and are most favored by the deer, soon after they sprout.
After that first cultipacking, I broadcast the white clover. Then, I cultipack a second time, 90 degrees from the first direction. The clover seeds do best down about 1/8” - 1/4” , and I get that, because the ground is already partially compacted when I broadcast the clover.
The cultipacker, used like this, provides the precise depth control that maximizes germination. The ridges that it leaves behind help with drainage, from heavy rains, that might otherwise wash away lots of the expensive seed.
For brassicas, slightly larger seeds than clover, I get the ground worked up (not as fluffy as for wheat/clover plots) broadcast, then cultipack just once. I’m looking for a seed depth of about 3/8” on those.
   / What implements do y'all have for food plots, and what do you wish you had? #22
Not tried it, but I've heard of good experiences, cheaply, by disking/chiseling/tilling, then broadcast black oil sunflower seeds, and then 1 final Light pass with a disc or chisel. I think if you rototilled, I would broadcast, drag, and tire roll?
   / What implements do y'all have for food plots, and what do you wish you had? #23
I mean cerial rye attracts them and it green under snow in central NY. The seed is cheap and you dont need any of this equipment to plant it.
I have a 40hp tractor and only once used the landscape rake on my food plots and that's because they where woods prior.
My cousin's daughter just bought some hunting land. I bought this old spring tooth as a welcome to thge neighborhood gift.
   / What implements do y'all have for food plots, and what do you wish you had? #25
I would get a tiller. If we ever do 'food plots', they will be for our bees.
We don't get winter, so deer have plenty to eat naturally.
   / What implements do y'all have for food plots, and what do you wish you had? #26
A disc harrow with 2-gangs. Notched discs up front gangs and rear smooth discs.
Food plots can vary in small open areas.
The trouble with a tiller is hitting tree roots or large rocks. It can explode a tiller gearbox in 1/2 a second.
Then you can use the same tool for the home garden.
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
