What implement(s) do I need?
/ What implement(s) do I need? #1
Apogee22
Northern Michigan
Kubota B2650
Recently purchased a corn field and am interested in any recommendations for knocking down these stalks to get them into the soil so they break down. Corn was feeder corn. My local dealer recommended a disc harrow. Is that a good recommendation? Do I need a sub soiler or single blade plow to get under those stalks? Or just run them all over with the edge of the FEL? Soil is sandy but rocky.
Sorry for newbie questions, there’s a lot of corn and we’re looking to get the soil ready for a new house and farm of our own.
/ What implement(s) do I need? #2
What are you going to do with the field long term? The reason I ask is if you want to turn it into a hay field then just hire someone to do it as opposed to spending money on something you will use once.
/ What implement(s) do I need? #3
A heavy disc harrow to cut up and incorporate into the soil. Ken Sweet
We’ll be building a house and starting our own farm on about half of the acreage. The rest will be sold off, but will be making a shared easement driveway on a good portion as well. Just trying to get this corn down now so it’s easier to move around the land.
/ What implement(s) do I need? #6
Kubota B2650 Dimensions​
Dimensions
Wheelbase:65.6 inches
166 cm
Length:101.2 inches
257 cm
Width:53.7 inches
136 cm
Height (ROPS):88.4 inches
224 cm
Height (cab):84.6 inches
214 cm
Weight:1786 lbs
810 kg (ROPS)
2293 lbs
1040 kg (Cab)
Ground clearance:14.6 inches
37 cm
We’ll be building a house and starting our own farm on half the acreage.
Awfully puny tractor for moving dirt.
Tractor weight is the single best indicator of tractor performance.
Few here would recommend an 1,800 pound bare weight tractor for more than three acres.
/ What implement(s) do I need? #7
A B2650 is too light to pull a Disc Harrow that will turn under corn debris.
I would burn the field first, if legal. Then mix the dirt with a PTO powered roto-tiller or rip the dirt with a three (3) shank All Purpose Plow, depending on your next use for the field.
VIDEOS: https://www.youtube.com/results?search_query=B2650+rototiller
Do I need a single blade plow to get under those stalks? Just trying to get this corn down so we can move around the land easier.
A single bottom moldboard plow will bury the stalks and deal with rocks fine. However, then you have the plow furrows to flatten........
/ What implement(s) do I need? #8
Looks to be quite a lot of acreage and the B2650 is a small tractor. I'd hire it out and get it done right. Heavier tractor and disk harrow or rototiller.
/ What implement(s) do I need? #9
I‘ve joined this group as a recent purchaser of a 2019 Kubota B2650 ROPS. The tractor has 330 hours on it and was a part of a package with a FEL, B2728B Snowblower, BH77 Backhoe, PFL2042 Forks and RB3596 Back blade. We’re in northern Michigan and primarily bought for 12 acres were closing on for constructing a large garden, house and driveways.
If your ground is moist your back blade should serve reasonably well as an expedient implement for knocking down the corn residue and first stage smoothing, though corn debris will remain on the surface. Set the back blade at about a 30 degree angle, where it will pull fairly easy.
VIDEOS: https://www.youtube.com/results?search_query=B2650+back+blade
/ What implement(s) do I need? #10
For sure if you do not know your future plans, have the field professionally done before you let it grow back in whatever. In ten years if it is not leveled and compacted properly you will have a rough ride even mowing. Unless you can penetrate the ground evenly, it will settle and leave ruts. I know from experience. I have a 20 acre piece that was not treated correctly and I must now and forever mow in a lower gear due to the rough surface. The other 20 acres was treated correctly and I can mow it in 1/2 of the time.
If you decide later to plant a garden or whatever you can till it up. If you want to have animals on it you can zip over it with a rotary mower much faster if it is smooth. If you hire someone for even $1000, ten years later it will have cost you $100/year to have a smooth field. If you buy a $500 implement and do not get it right you will spend 10 years driving slowly over your field and have saved $50/year.
Bite the bullet, spend the money, drive in a higher gear and do not look back. Even consider having it drilled and seeded to what grass you desire.
You may only get this opportunity once...
/ What implement(s) do I need? #11
If the construction of the house/buildings will be started soon, I say just mow it with a rough cut mower.
If you work the ground up now, when it rains or snow melts, the ground will turn to mud. The deeper the ground gets tilled, the deeper the mud.
Wet ground with cornstalks on it is much firmer than worked up ground.
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Front Tank Bracket (A64126)
Front Tank Bracket...
Peanut Wagon (A64127)
150 GALLON FUEL TANKS WITH BRACKETS (A65643)
150 GALLON FUEL...
2018 FORD F-350 (A65643)
2018 FORD F-350...
