/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,011
I had to weld my hood bracket in again. I should've "grinded" down the ends better.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,012
Finished up a project to put a grill guard and weights on the front. I got a receiver hitch out of my neighbors scrap. Cut it down and welded a plate with bolts. The guard pivots down to open the hood. The weight is actually 2 75' plates i traded my neighbor for. There is a receiver welded to the plates so I can easily remove them. Drug a few logs out of the woods for firewood. Happy with it so far.
Next plan is to add box to it for carrying chainsaw and other tools.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,013
Nice!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,014
I changed the oil and filter on my GC1723 today. Then I changed the fuel filter. What a pain. I don't have the mid mount mower, so the linkage that connects to the mower deck needed to be lowered to get access to the fuel filter. Well the knob that locks that linkage in the up position was frozen and would not turn. I had to put a wrench to it to get it to move. I was afraid I would break something, but all ended well. The linkage dropped down and when I was done, I put it back up and locked it in the up position again.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,015
They must have changed something on the newer models. I don't have to lower the linkage on mine to to change the fuel filter.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,016
I didn't have to lower linkage on the 2020 gc1723 and 2021 GC1725M
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,019
I had to move a large rock out of a path through the woods today. To large to lift so I dug a hole and was able to stand up and roll in.
This small mf is a great little machine!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,020
Anybody else have a problem with the boom control on their 1725mb. Second time it broke. Went to a different dealership and they had the new improved replacement. $190 part Kanuckistan money or aboot $5 US.
Easy enough fix but I wouldn't expect it twice in the first 120 hours with limited backhoe use.
Hunter TCX53 Tire Changer (A50121)
Hunter TCX53 Tire...
PT 500 Gal Water Tank (A50121)
PT 500 Gal Water...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
TEST BID LOT (A50774)
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
