/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,341
No buildup here but on Easter had 2 periods of approx 30 minutes where hail in one area and 20 feet away light snow. Weird.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,342
serviced neighbors 2021 GC1725M TLB ( 121 hrs) today. found hydro drive low. saw fan/input shaft seal leaking.
gonna call dealer in few days to arrange a pickup.
gonna use it to dig around some stumps friday so I can drive chainsaw into ground to cut roots. then pull them out with larger tractor. got a few spare saw chains....
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,343
Use a sawzall on dirty roots. Much better than a chainsaw resharpen every 2 minutes.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,344
So our predicted wet snow has finally arrived, about 1-1/2 hrs behind schedule. Was only rain with a few wet flakes mixed in 2 hrs ago, but now all snow and building up.... Looks like winter out there! Grandkid might get a snow day or delayed opening after all.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,345
I have over a foot of wet heavy snow. I'll be heading out to move it soon. Getting to start late because everything is closed and no one needs to get out makes it so I don't have to do it in the dark. This much snow this late in the year is my definition of hell. Really glad I decided I'd wait on removing the snow gear from the tractor.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,346
not large enough for 3 of the stumps. used spade dug one root out a bit yesterday and won't work. plus where I can't get under the root blade would hit. cut to cut 11 roots. one chain will work.
other 3 are small and massey will yank out.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,348
Just ordered the Brotek rear skid plate. Yes, I already knocked off the hydraulic filter, so it is after the barn door was open and the barn burned down.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,349
stump puling.
friggin hybrid poplars.
used GC1725M to dig out roots and most dug and pulled out (using GC2400) hard.
2 stumps were 7-8" diameter, one was 5", and other was 4".
think they would be easy right? not.
biggest issue was when I felled them I cut too low as was giving away for sawmill and some for firewood. should have cut at 4 ft height.
first up was the 8" diameter one. it had a 7" root going close to straight out of stump into hillside (meaning UNDER my septic field) and was almost 2 feet deep to start with. took 20 minutes to dig away enough to hit with chainsaw. hole here about 8ft diameter and 3ft deep.
second stump, 6-7" diameter has much smaller roots but a ton more of them. pulled approx 10 feet of one out with it, other 2-4 feet. hole there about 12 feet diameter and maybe 2ft deep.
third was the 4" one.
simple used backhoe never touched with chain. just had to dig about 2 ft although diameter was only maybe 4ft.
fourth up was a 5" or so stump with lilacs 2ft away on both sides. hope I didn't hurt lilacs, did hit some of their roots.
digging this one not too bad, sandy soil, but pulling it out was PITA as it wanted to roll instead of get pulled.
the 2 15-20" spruce and the 45" poplar stumps...gonna get cut to the ground and use a drill to introduce the stump to kerosene. who knows what will end up happening after that introduction. maybe the 2 will act all cold towards each other, maybe the relationship will heat up. time will tell...
tractor wise the old GC2400 worked like a champ. the first 2 on field/lawn I pulled in 2wd. the ag tires spun 1/8 turn lugs dug in and either stump came out or front end lifted 4" in the air and everything just stopped. full throttle could not get to spin or move. engine was grunting hard. on the 4th was sandy soil so did use 4wd and just hit diff lock when ready to yank out once . 3 spin marks in the soil :p
the GC1725M had power but on sod I really prefer the stabilizer pads (flip type) the GC1710 had. I've pulled lot of roots with that and had much better hold on sod then the u-shaped pads the GC1725M has.
oh well swapped a service for use of backhoe on it, and can use any time I want so I ain't complaining.
did find (during service few days ago) seeping input shaft seal (behind fan) on a tractor with only 121 hours on it. he's gonna call dealer monday, I verified the seep today. I cleaned area when servicing, ran few hours today, glistening film around seal where I cleaned. lets see if they will honor warranty.
anyways...next up is to hook chains to some roots in holes and go for a ride in the GC2400...
EDIT:corrected image for third stump
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,350
Added a $6 Ebay decal to my ammo can toolbox. What do you think?
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
Grundfos Centrifugal Pump (A50121)
Grundfos...
