What have you done in preparation for the 2020 hay season?
   / What have you done in preparation for the 2020 hay season?
Thanks for sharing the pics.
It's so interesting to see how other parts of the country produce hay. Down here, there are no rocks or snow in my hay fields! :D
Peter, are you producing or buying the big squares?
I brought my baler home last week. It's supposed to be ready to go. Also managed to bush-hog the Bermuda patch. The native winter grass needed clipping. The cows are clipping the other 40 acres right now.
We're maybe 4-6 weeks away from the first cutting.
   / What have you done in preparation for the 2020 hay season? #12
They've already rolled about 6 acres of Abruzzi Cereal Rye here. There's another 10 or 11 acres on the ground now to be baled tomorrow, weather permitting. It was a little thin this season due to record rainfall over the Winter. A few these first bales tested a bit high on moisture but son were basically out of hay so you gotta do what you gotta do.
   / What have you done in preparation for the 2020 hay season? #13
Nice looking hay. I noticed the rounds looked a little soft - probably good if moisture is high. Can your round baler be tightened up? Around here they are rock solid and if soft like yours don sell well. Just curious.
   / What have you done in preparation for the 2020 hay season? #14
Well to get ready I drag harrowed with weight on it this year. Did a cross pattern too. But before I did that I placed about 20 yards of composted horse poo on the fields to level out any dips and low point for better irrigation water flow. I then reseeded some areas. The harrowing got the seed into the ground.
I still need to fertilize but will wait for weather pattern to change - were in a dry spell right now.
   / What have you done in preparation for the 2020 hay season? #15
I buy it out of Vermont..... sorry missed your question back then.....:eek:
   / What have you done in preparation for the 2020 hay season? #16
I fertilized back in December. Applied 200 tri axle loads of compost to my fields with the Hagedorn terd hearse :laughing:
   / What have you done in preparation for the 2020 hay season? #17
Applied 50 tons of Lime, 8 loads of chicken litter (manure) Bought a Vermeer TM610
All we need now is Rain to help it grow!!
   / What have you done in preparation for the 2020 hay season? #18
Stripped down and rebuilt the cutter bar on my disc mower, currently working on the old drum mower replacing a couple bearings, made and fitted new gates for the haybob, serviced the old Massey 703 baler and got some work to do on the New Holland 68 baler. New drive belt and pulley on the belt rake. Waiting on new parts for the 4 rotor Tedder to replace some tines. And that’s just the work on the machinery!!
In the field we’ve put out slurry, nitram fertiliser and lime, brushhogged the Sh!te that didn’t get cut end of last season and then cut the hedges
   / What have you done in preparation for the 2020 hay season? #19
Just got a load of 2019 second cut hay yesterday.......41120 hay.jpg41120 hay1.jpg41120 hay2.jpg
   / What have you done in preparation for the 2020 hay season? #20
1990 TRAILMASTER CRUDE TRAILER (A58214)
1990 TRAILMASTER...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
MARATHON 20KW GENERATOR (A58216)
MARATHON 20KW...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
Utility Tilt Trailer (A55787)
Utility Tilt...
