What grease do you use on your zero turn pully's?
   / What grease do you use on your zero turn pully's? #11
I’ve had belts on my Zero Turn that were evidently just slightly stretched enough so that, if I bumped the deck hard enough against something (like circling around a tree truck), the belt would jump off. New belt fixed that, but you said you’ve changed the belt. Did you use a new belt, or just a spare used one?
Belts where bought brand new last year with no change or improvement.
I mowed yesterday. It worked fine the first three times I turned on the blades, then threw the belt on the forth time. That's never happened before. After putting the belt back on, it didn't do it again. It's almost like it enjoys doing it once, and then that's enough.
I turned the blades when the belt was off and I didn't notice any wobble or movement in them. I don't think it's the spindles, but maybe it is and I'm not seeing it.
From reading everyones comments, and other threads on grease, I don't think that's my issue anymore. The Lucas Red and Tacky is probably as good as I'm going to get.
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
14C SCRAPER (A58214)
INOP Kawasaki Bayou 250 Four Wheeler (A57453)
INOP Kawasaki...
SCREENER (A58214)
SCREENER (A58214)
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
