How about a grease cartridge thread?
   / How about a grease cartridge thread? #51
4570,
It works on pins too, just have to keep up with it and grease on schedule. I have an organic farm and try to keep tractors tight and dry. Milwaukee M18 grease gun makes quick work of greasing.
   / How about a grease cartridge thread? #52
4570,
I guess you could not wash your hair for a week and rub on the pins too but there’s far better options available.
   / How about a grease cartridge thread? #53
Non toxic?
   / How about a grease cartridge thread? #54
   / How about a grease cartridge thread? #55
   / How about a grease cartridge thread? #56
4570,
All farms are organic. I've never seen anyone raise inorganic crops or critters.
   / How about a grease cartridge thread? #57
I learned years ago that lithium based moly if far superior to regular lithium. Moly gives you an extra edge against washing out plus it is much slicker. That is the reason it’s the most common high pressure ingredient. I’m not so brand loyal but a quality high pressure grease is my pick. Anti-seize is basically a moly lube fortified with a variety of metals for specific applications. I use 2/0 picker grease for gearboxes. It doesn’t leak out like gear oil and is used commercially in “permanently lubed” gearboxes. So far so good.
   / How about a grease cartridge thread? #58
Rental yard owner turned me on to TRC 880 so that is what I use.
Texas Refinery Corporation has a full line.
I will only add that mixing non compatible grease can be very bad…
A few boat trailer friends found this out.
   / How about a grease cartridge thread? #59
I have not purchased a tube of grease in decades. Buy all my grease in 150 pound open head drums and bulk refill all my grease guns from the air greaser. Just purchased a 150 pound of Lucas Red and Tacky to replace the almost empty drum of Lubrication Engineers Teflon fortified grease I usually use as the shipping on the Lucas beat the pants off the LE grease and I (so far) have no issue with the Lucas.
A 150 pound drum usually lasts me 2 years or so.
No messy cartridges to deal with or dispose of and no greasy fingers or clothes either. The air greaser was a good investment for me.
It's an ARO btw and it wasn't cheap but then quality American made products usually aren't.
Each of my lever guns is fitted with a bulk load fitting and all my guns have clear barrels so I can see what's left in them.
Easy to fill and no mess.
   / How about a grease cartridge thread? #60
My first time attempting to fill a cartridge with grease was from a five gallon pail no cartridge and no pump. I tried to hold the bottom of the barrel in the grease and suck the grease into it by slowly pulling back on the plunger. Grease went many places and very few were inside the gun. When I finally got a box of cartridges I felt like a grease monkey gone to town.
Many years ago we got our grease in the 4? gallon/40# keg, under the cover it had a follower plate with a hole in the center. You would unscrew the head of the grease gun then stick the barrel down into the hole in the follower plate and pull on the handle to suck the grease into the grease gun, then fight to get the rod over into the notch to hold it retracted till you could screw the head back on and then unscrew it a couple of turns to "burp" the air out of it.
Then we got fancy and got the pump to go on the grease bucket with a large fitting which would mate up with the large fitting on the head of the grease gun and pump the dispensing pump to fill the grease gun while watching the plunger rod slowly extend out.
Dang we sure were pleased when the switch over to tubes was done.
I don't recall getting any plastic tubes all mine have been in cardboard tubes.
That said I haven't had to buy any in quite awhile as I picked up several cases a couple of years ago. Less then a case left now. I've been using the Amsoil greases for quite awhile.
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
