Loader What Goes Up Doesn't Necessarily Go Down!
   / What Goes Up Doesn't Necessarily Go Down! #11
Flow = speed, pressure = power. If you don't have the power to lift the front end, you don't have the pressure. If the pump pressure is good, then it's bypassing somewhere. Most likely the cylinder seals or the control valve. Cold oil is thicker than warm oil, so any sealing problems are going to get worse once it's had a few cycles.
Hydraulics are simple to troubleshoot, just messy. Personally, I'd disconnect the lower hoses from the cylinders, let the oil drain out, then try to curl down. If you start getting an increasing amount of oil coming out of the cylinders, the seals are bad. If not and it still won't curl down, pressure isn't making it to the cylinders. At that point I'd be looking at the valve bypassing internally, hoses collapsing internally or bad quick connects. If it does curl down with the bottom hose disconnected, you probably have a return line blockage, so again, valve, hoses, quick connects.
Hello Cioti,
Just wanted to THANK YOU for your input on this issue. It's been going on for several years. The tractor lifts full buckets of trap rock with no issue but still has a problem with lifting the wheels up. One other issue I ran into was lifting about 1,000 lbs of blocks for a retaining wall that we were building. My tractor is supposed to life just over 1,155 lbs yet it couldn't lift the 1,000 lbs. My friend has a Kioti 2510 that's about a year old and he lifted it with NO ISSUE AT ALL! I am still thinking it could be somehow in the pump area.
I have printed your suggestion and will be taking it to the dealer when I take it in for service very soon.
THANK YOU AGAIN!
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
