What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #441
I ordered a nice plastic pallet, the most common pallet size and 6000 pound capacity ... also plan to use it as a work platform ... relying on it not to fall. (Yes, FELs aren't supposed to be counted on for safety, but I think a fall from 4 or 6 feet is a small enough risk.)
I had a scare back when I was a carpenter. First day on a job I was assigned a forklift with a non-code platform with a railing, to work on a second story window. Then I drove the rig to the next window ... and when I went over a bump the platform fell to the ground.
I found a fresh - and broken - weld where the lift chain had been attached to the platform.
   / What else do you do with forks besides lift pallets? #442
Shop loaded my little Yanmar into my trailer ...
p1530374rloadingym186datdaves-jpg.460565
   / What else do you do with forks besides lift pallets? #444
Didn't stop for pics, but I used mine to load up an old washer and dryer into the back of my truck to haul them to the dump.
Love them forks, sure are a back saver.
   / What else do you do with forks besides lift pallets? #445
i think they would be useful as an engine hoist, but I have one of those already
holding lumber at a build site (chicken coop)
   / What else do you do with forks besides lift pallets? #446
How about packing the Afton stone (crushed limestone) I just spread. Rear tires are loaded on the BX2230, loader bucket full of dirt, IBC totes filled with 125 gallons of water on the rear forks. I added water to tote with the 3pt arms in the up position. After a while, it had settled a bit and had to use the B26TLB bucket to raise it up. Jon
   / What else do you do with forks besides lift pallets? #447
Similar here, forks as part of a grading project.
Most land planes are simply towed. But I need the ability to lift this one, using the forks, for tight U-turns when smoothing my narrow lane. The cross-chain in the photo allows this lift.
I took this photo when I was improving it with a permanent chain on each front corner, with hooks to pull it from the front of the forks assembly.
Also, setting the weight of the forks on the land plane makes a crude blade for levelling gopher mounds in the orchard.
20210321_194855rlandplaneinshop-jpg.693293
   / What else do you do with forks besides lift pallets? #448
Holding a workpiece up where you can get at it, and moving it around for the best angle!
I did this with my bucket (before I had the forks) with a short set of pressure treated lumber stairs I was fixing for the front walk. I held them up where I could work on them easily to drive a bunch more screws and hose all the detritus out of the way. It was helpful but would have been even better with the forks.
I may use them when I treat a plywood slab with linseed oil later this week.
We plan to build a set of planters for a border to the driveway. I figure not only will I use the forks for whatever is easier when held up high, but I will also actually design the planters to fit the forks, so I can reposition them easily. For example, the planters will block cars from rolling off a high bank, but I may relocate one planter to make room for dumping snow down that bank in the winter.
   / What else do you do with forks besides lift pallets? #449
My photo above in post #447 also shows the unique 3-point forks assembly that I built from scrap materials, for use with the Quick Hitch. Recommended!
Here's a photo using the forks. The platform has a bedframe angle iron perimeter, over a pallet.
20191106_163749rym186d-harvestgrannies-jpg.633196
And another use of the forks to carry something. This photo most clearly shows how the forks are made.
I built the forks as a temporary solution for some project, intending to buy 'real' forks later, but these have held up for 15 years without damage. So no need to upgrade.
20190625_104217rrearforks-blue-jpg.635377
   / What else do you do with forks besides lift pallets? #450
Eat dinner.
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
Chemical Containers Tank (A57148)
Chemical...
MMS MS36C Skid Steer (A57149)
MMS MS36C Skid...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
MULCHER (A58216)
MULCHER (A58216)
2001 DODGE RAM 3500 (A58214)
2001 DODGE RAM...
