What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #351
A double set of forks is also handy in addition to picking up two pallets side by side
And fork extensions of course.
   / What else do you do with forks besides lift pallets? #352
A Grapple System would be the way to go but I'm thinking a couple of straps will work just fine.
The amount of brush I have and will have is small and I can not justify a grapple, even the top jaw.
My last run at another section of the land I used a large Tarp, secured with straps, awkward but it worked, hoping the Forks will reduce the amount extra work the Tarp was.
You will not regret getting the forks.
   / What else do you do with forks besides lift pallets? #353
My plan was to slide the Forks under the brush pile, mount an Eye Bolt or drill a hole in the end, and hook up some ratchet straps.
I just wanted to reduce the amount of manual labor piling brush on a Tarp, then the straps.
Any thoughts on who would have a good deal ?
Medium duty should work for me but HD if the price is right.
Thanks for any and all-out only situation.
Ltr
   / What else do you do with forks besides lift pallets? #355
In my shop building process I've used my 3 point forks for a lot of stuff... we used them to haul the posts to their relative holes, used them to move the fastener pallet closer to the project, used them to move a LOT of 2x6's to the project (100' or so from where the units of wood were dropped off), and with a hand truck as a trailer put one end of the trusses on a pallet one at a time with one person holding them upright backing them into place (that wasn't the most efficient, but was nifty). No pictures of any of that, but it was a back saver...
Oh, and after I did some repairs on my rear finish mower in the driveway, I just picked it up with the forks and moved it to the side yard... was much easier than rigging it up under the loader like when I drug it to the driveway :)
   / What else do you do with forks besides lift pallets? #357
I use my forks as an adjustable table.
Depending on what I work on I lift it up to the height of me sitting in a comfortable chair. My back can't stand the bending over and my feet can't take hours standing in one spot to fix something. It works great. If I need a table that's adjustable I just use a 4x8 sheet of plywood.
   / What else do you do with forks besides lift pallets? #358
Since I just have a little BX my forks are only 36in but I did rip down a 3/4in plywood sheet for an adjustable height work bench for when I want to work outside. It is handy for messy jobs, painting :thumbsup:
   / What else do you do with forks besides lift pallets? #359
I bought heavy duty 4' forks and I wish they would have come with holes in the ends for chain hooks. Not sure how hard they will be to drill. I would imagine they are hardened steel.
   / What else do you do with forks besides lift pallets? #360
They are really easy to drill.
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
John Deere 4600 (A53317)
John Deere 4600...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
