What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #351
A double set of forks is also handy in addition to picking up two pallets side by side
And fork extensions of course.
   / What else do you do with forks besides lift pallets? #352
A Grapple System would be the way to go but I'm thinking a couple of straps will work just fine.
The amount of brush I have and will have is small and I can not justify a grapple, even the top jaw.
My last run at another section of the land I used a large Tarp, secured with straps, awkward but it worked, hoping the Forks will reduce the amount extra work the Tarp was.
You will not regret getting the forks.
   / What else do you do with forks besides lift pallets? #353
My plan was to slide the Forks under the brush pile, mount an Eye Bolt or drill a hole in the end, and hook up some ratchet straps.
I just wanted to reduce the amount of manual labor piling brush on a Tarp, then the straps.
Any thoughts on who would have a good deal ?
Medium duty should work for me but HD if the price is right.
Thanks for any and all-out only situation.
Ltr
   / What else do you do with forks besides lift pallets? #355
In my shop building process I've used my 3 point forks for a lot of stuff... we used them to haul the posts to their relative holes, used them to move the fastener pallet closer to the project, used them to move a LOT of 2x6's to the project (100' or so from where the units of wood were dropped off), and with a hand truck as a trailer put one end of the trusses on a pallet one at a time with one person holding them upright backing them into place (that wasn't the most efficient, but was nifty). No pictures of any of that, but it was a back saver...
Oh, and after I did some repairs on my rear finish mower in the driveway, I just picked it up with the forks and moved it to the side yard... was much easier than rigging it up under the loader like when I drug it to the driveway :)
   / What else do you do with forks besides lift pallets? #357
I use my forks as an adjustable table.
Depending on what I work on I lift it up to the height of me sitting in a comfortable chair. My back can't stand the bending over and my feet can't take hours standing in one spot to fix something. It works great. If I need a table that's adjustable I just use a 4x8 sheet of plywood.
   / What else do you do with forks besides lift pallets? #358
Since I just have a little BX my forks are only 36in but I did rip down a 3/4in plywood sheet for an adjustable height work bench for when I want to work outside. It is handy for messy jobs, painting :thumbsup:
   / What else do you do with forks besides lift pallets? #359
I bought heavy duty 4' forks and I wish they would have come with holes in the ends for chain hooks. Not sure how hard they will be to drill. I would imagine they are hardened steel.
   / What else do you do with forks besides lift pallets? #360
They are really easy to drill.
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A57453)
2013 Dodge Charger...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
Misc Vehicle Parts (A54816)
Misc Vehicle Parts...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
