What does this mean?
   / What does this mean? #1
Fastball
North Okanagan, British Columbia
Kubota L2900
Hi..am new to the world of fulltime tractoring - having inherited my dad's Kubota L2900. As I don't know the last time Dad had it serviced, I am leafing through the owners manual to the periodic maintenance section. When i check the transmission fluid indicator (the little glass thing in the back of the tractor), it is all white. Does this mean the tranny fluid is low and needs topping up?
Thanks..
   / What does this mean? #2
G'day Mate. Hydraulic oil/fluid turning milky white generally means that water is entering the reservoir.
You're going to have to do a full fluid/filter change. That should correct the situation.
Thanks, Wag....since I don't know what a full/low level looks like, I thought it might be just low. I'm thinking that I'm going to call the dealer to get a service guy out here for an hour or so - and watch him like a hawk as he goes over this thing from stem to stern. I haven't a clue when this was last serviced, so I might as well start with a clean slate. Pay the professional and learn from what he does.
   / What does this mean? #4
Park it going UP an incline, lower the rear 3pt hitch and front end loader (if it has one), and set the parking break. Now go look at the sight glass and see if it is now a slightly different color. If it is, you are low on fluid. You still might need to change it though...
   / What does this mean? #5
That's actually a prudent thing to do, even though it's going to cost you $s. If you're just starting out, having an 'on site' full servicing done will, indeed, allow you to observe and learn about all of the eccentric/mysterious things of your tractor. It'll be money well invested so that the next servicing can be done by yourself, with confidence. Pesky/hidden grease nipple locations will be another thing to watch out for.
When it comes to changing fluids, not all of it will drain out (no matter how long you let it drain. The listed capacity in your Owners Manual is the total capacity. Always fill up just shy of the "total"... then come back the next morning and guestimate the amount to top-up to the full mark.
ALWAYS change/fill your fluids when you tractor is on a level surface.
   / What does this mean? #6
All excellent advice. A picture is worth a thousand words.
   / What does this mean? #7
Sight glass indicators can be very difficult to establish if they have oil in them or not as there is little difference in color if there is oil there or not, unless they are at the halfway mark. As mentioned, parking on an upwards slope and downwards slope away may show a difference in color and you will get used to the indication. (Or sideways slope etc depending on your tractor) The addition of a coloring agent can also help, looking in the filler hole can also help.
Generally white is low, yellow tinge is full, however the plastic yellows over time making it hard to see.
   / What does this mean? #8
To everyone (including the OP): sorry, my bad. My 4105 has a dipstick and I misinterpreted what the OP meant by 'showing white'.
I thought that it was the actual colour of the fluid. :eek:
   / What does this mean? #9
I ran a "bota" on another farm, that sight glass aggravated the fire out of me, owner just laughed & said run it.
Ronnie
   / What does this mean? #10
The only oil level sight glass I ever had was on a motorcycle and it was a PIA to use. You couldn't see it unless you were squatting down or on your knees and the bike had no center stand. It was really a 2 man job to check the engine oil in it, one to hold the bike level and the other to be on his hands and knees to look at the sight glass. As stated, even when you can see them, it is difficult to tell if you are overfull or under filled if the glass has yellowed a bit.
I just cant understand why manufacturers cant provide a dipstick for all oil levels.
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
John Deere Gator (A53317)
John Deere Gator...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2019 Toyota Rav4 LE Hybrid AWD SUV (A55853)
2019 Toyota Rav4...
