Oil & Fuel What do you use to fill your JD with Diesel?
   / What do you use to fill your JD with Diesel? #1
mx125
Toronto
JD 2320
This sounds like a silly question, but my 2320 arrives next week and wondering what the concensus method is for filling the tank. Do most of you use a good old red plastic container . . or do you go with a bigger one and some sort of hand pump?
The position of the filler cap looks a little akward with a heavy fuel can . .and i can anticipate pouring diesel everywhere. Maybe it's easier than i think.
With a 5-6 hour?? tank range I would think two cans might be needed.
   / What do you use to fill your JD with Diesel? #2
I use a YELLOW 5 gallon fuel jug for Diesel. Red is for Gasoline, Blue is for K1.
You should average about 1/2 to 3/4 gallon per hour of fuel.
   / What do you use to fill your JD with Diesel? #3
mx:
I set a yellow (I don't want my old brain to get confused between gas and diesel) 5 gal plastic diesel container on the hood, and use the pump syphon, that I originally got for $2.95 to fill a portable kerosene heater, to transfer the fuel. A couple of pumps and it drains the diesel into the tank.
Steve
   / What do you use to fill your JD with Diesel? #4
For now, YELLOW fuel cans, one from Walmart, better one from somewhere else.
It is kinda a pain holding a full can 5.5 feet in the air to refuel, so I'm debating whether to get an on-farm tank of some sort.
I won't forget to go with yellow or blue . . .as you say . .i already have enough gasoline powered things I would screw up.
I will look for a pump siphon . . .that sounds more elegant.
And that's good news on consumption. The JD specs had me thinking it would use 1.6g/h . .or 3.8hours at full throttle. I knew I'd have idling time to increase that . .but your estimate is twice or better than I thought. Great.
Thanks for the insights.
   / What do you use to fill your JD with Diesel? #6
I use two 5 gallon diesel plastic jugs. Soon to add in a 30 gallon drum and pump, and of course additive. Yeah it is a little overkill, but I kinda like overkill.
   / What do you use to fill your JD with Diesel? #7
I use fuel pump/nozzle/filter mounted on 100 gal fuel tank from TSC. Little expensive but I have three diesel tractors to fill.
   / What do you use to fill your JD with Diesel? #8
mx125:
I also use a Mr. Funnel. Jay
   / What do you use to fill your JD with Diesel? #9
I use 5 gallon Klotz fuel cans. They have a metal spout that pulls out. I was going to use one of my 250 gallon bulk tanks but decided not to because of the fuel sitting too long before use. I think it's better to have fresh fuel. I also use a funnel with a paper paint strainer liner.
Attitive? Interesting. . .do you recommend a stabilizer due to the infrequent use . .or is there another additive that is importand for diesels?
If it's the former . . Is there any downside to constant running with fuel stabilizers?
And i'll be sure to bring a funnel if I can't find a nice neat siphon solution.
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
