What Do You Do With Your Waste Oil?
   / What Do You Do With Your Waste Oil? #11
It goes back into the 2 gallon jugs it came out of and then I take them to the local O'Reilly's, Autozone etc. Sometimes they enforce the 5 gallon limit, most times not. My 20 gallon HF oil drain dolly is about full, time to fill some oil jugs!
   / What Do You Do With Your Waste Oil? #12
I drop it off at Walmart, Auto Zone, Advance Auto, etc.
   / What Do You Do With Your Waste Oil? #14
Where does the oil go ? Landfill ?
   / What Do You Do With Your Waste Oil? #15
Picked up by jobber and either rerefined or sold to many businesses the can use it, it does not go into ground.... Locally there is a steam excursion rail line that burns the oil to heat their boilers...
   / What Do You Do With Your Waste Oil? #16
I store mine in wide mouthed 5 gallon firefighting foam containers, then take them to the county recycling center in my area. They have a 5 gallon limit.
I believe most states require places that sell oil to accept waste oil, but I've never tested that here in Maryland. The shops that use the waste oil for heat that I have talked to will take oil, but don't allow me to pour it in due to concerns that have been mentioned above. I'm not leaving my containers.
   / What Do You Do With Your Waste Oil? #17
I recycle it unless I use it to start my slash pile burns in the spring with it, motor oil and sawdust are good slash pile starters without the danger of explosive effect like gasoline.
   / What Do You Do With Your Waste Oil? #18
I drop mine off at a local garage that has uses a waste oil furnace for heat.
   / What Do You Do With Your Waste Oil? #19
All the numerous county funded recycling centers around here take it for free. Most of the automotive repair places have waste oil heaters so I’m guessing they would take it.
   / What Do You Do With Your Waste Oil? #20
My understanding is it has some value. I’m not sure what they do with it but I think it was Valvoline was advertising there was a “green oil” that was using some percentage of recycled oil.
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
2013 Ford F-550 4x4 Auto Crane 4004EH 4,000lb. 2 Ton Crane Service Truck (A55973)
2013 Ford F-550...
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2015 GMC Yukon (A56859)
2015 GMC Yukon...
