What do sparks mean?
/ What do sparks mean? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I was tilling a neighbor's garden tonight and I saw sparks coming out of my exhaust. It may just be that this is the first time that I ran the tractor very hard in the dark (work has been pretty busy lately), but I haven't seen sparks come out of the exhaust before.
Is that normal?
Does it indicate that there might be some problem?
Like I said, I was tilling. I was running at pretty high RPM's and working the tractor hard but not really "Lugging" the engine or anything.
/ What do sparks mean? #2
It probably is rust scale in the muffler and pipe blowing out.
They are very thin and are "glowing red" when they come out.
I see it on some of my equipment that may set for a while between work outs. Dosen't take long for something to have surface rust after being hot..
/ What do sparks mean? #3
I have seen it many times on gas engines. Usually it is just rust spots in the muffler or pipe. But I can't say I have ever seen it on a diesel?
murph
/ What do sparks mean? #4
My ford 1910 has always made sparks at night. I think it is quite normal.
/ What do sparks mean? #5
Work any engine hard, and you will get rust scale, carbon deposits and other detritus blowing out the exhaust. It is normal. Not much on a tractor to "trap" that stuff before it makes it to the outside world.
neat anecdote: we have an old 806 International that had WAY too much fuel turned to it. On a cool night, pulling a 12'7" cutting disc, it could be made to run about 4" of fire from the exhaust. looked cool, but not a good idea to keep crowding it like that though. /forums/images/graemlins/grin.gif
Don't worry about the sparks. they are normal.
/ What do sparks mean? #6
I'll second what Hud has said. My old B7200 Kubota used to do this on regular basis when you work it hard. I used to notice sparks every five to ten seconds when I was snowblowing at night. Some of the newer machines do have spark arrestors on the exhaust. With most forestry equipment I think it is pretty well mandatory to have spark arresting exhausts.
Steve
/ What do sparks mean? #7
Iplayfarmer,
I have to agree with what the others have said. It could be rust or loosened bits of carbon somewhere in the exhaust system.
This is why the Forest Service wants all engines to have some sort of spark arrestor on the exhaust.
Be careful that you don't start a grass fire when conditions are dry.
That could be a big OOPS! /forums/images/graemlins/blush.gif /forums/images/graemlins/shocked.gif
/ What do sparks mean? #9
I, too, encounterd this phenomenum this summer with our old L245 while running flat out down a gravel road to bushog. It was mid day, so I didn't see it but felt it. I thought gravel was hitting my arms. It was the muffler/stack self-destructing from rust.
/ What do sparks mean? #10
IPF:
I agree with all the other posters that it's probably perfectly normal. I experience the same thing when cutting wood as the light is failing - I can see little sparks flying that I don't see in the daytime. And of course I mean when cutting good clean wood, not dirt or rocks - THOSE sparks I CAN see in the daytime. /forums/images/graemlins/tongue.gif
I guess the sparks are from little bits of mineral in the wood that account for the unavoidable kind of dulling of saw chains. If the chrome edge of the cutters never encountered anything harder than themselves, maybe theoretically a chain would stay sharp forever.
Thanks for the answers. Like I mentioned in the first post, I was running at a pretty high RPM. I guess these sparks were just parts of the muffler flaking off and coming out.
It sounds like this isn't anything to really worry about, but I might want to start planning for a new exhaust stack. That makes the most sense. I'm starting to see a little rust on the bottom of the stack where it comes out of the tractor. It would stand to reason that the inside doesn't look much better.
/ What do sparks mean? #12
If what you're doing isn't working, do something different
IPF, that simple yet profound signature of yours just hit me like a ton of bricks. Hadn't noticed it before. By god, that's just what I'm going to do - thanks!
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
17394SFL (A61568)
17394SFL (A61568)
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2022 DEMCO KARKADDY X 9713093 CAR DOLLY (A64277)
2022 DEMCO...
