What do I really need?
/ What do I really need? #1
vallyfarm
Upstate N.Y.
Hi guys, I've been reading around here for some time now...a lot of different forums, and from everything I've gathered, the Yanmar is the tractor I'm looking for. What I need it for is to be small enough to clean out the goat pens with a loader, rototill approx. 5 acres of rowcrop garden, and ocasionally mabey pull a 1 bot. 3 pt. plow in well worked soil. Of course pulling wood wagons, etc. will come too. I've got plenty of larger tractors, but they ar just too clumbsy to wook in the tight areas of the strawberries and taters. I would get a 2wd. mod. because I've never needed anything more, and like to avoid as much "weak links" as possible. Sorry so long, but appreciate any feedback. Mike
/ What do I really need? #3
Would a 1610 be too large for you? I really couldn't see using a smaller model pull a single bottom plow. In my opinion, power shift is the only way to go.
/ What do I really need? #4
/ What do I really need? #5
I have A ym1700 and it want pull a bottom plow very good . I would go with the 2210 it is 26HP.
/ What do I really need? #6
/ What do I really need? #7
"I would get a 2wd. mod. because I've never needed anything more, and like to avoid as much "weak links" as possible.'
I would definitely go with a 4wd if you expect to pull a plow. As you said, you have never needed 4wd, but you have had larger tractors. Compact tractors are much better at pulling ground engaging implements with 4wd.
/ What do I really need? #8
/ What do I really need? #9
4 wd can come in handy with a full loader bucket also. I sometimes get stuck with a heavy load on soft deep gravel or mud. I have to dump the load and get un stuck. 4WD would be very handy then although maybe I would just dig all 4 tires in? I use my 2210 around the horse barn. It is sized ok for that. It is not as handy as a little skidsteer but it manuvers ok in tight quarters....Power shift is the way to go!!!!
/ What do I really need? #10
/ What do I really need? #11
I am using a 1510D to clean horse stalls with a Koyker 80 loader. The loader is approx. 38" wide and the tractor is 40" wide at the rear wheels. This gives me plenty of clearance to get through 4' wide doors. Make sure you know your door/gate widths of your pens before you decide on a tractor/loader. Everyone who said go with powershift is right! So much easier. I would also listen to them about 4wd. Tractors with a load can get stuck fairly easily I've learned. I think I would be regretting it right now if I had bought 2wd.
/ What do I really need? #12
2007 CHEVROLET SILVERADO 1500(INOPERABLE) (A67714)
2007 CHEVROLET...
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
2019 Yanmar ViO35 Midi Excavator (A66734)
2019 Yanmar ViO35...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2018 Kawasaki 4x4 Diesel Utility Cart (A66734)
2018 Kawasaki 4x4...
