What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,121
I made a snow blade for my FEL. Bought some UHMV poly from Amazon. They were supposed to be 48in long but it was 47 and 3/4. They were 3/4in thick. I bolted it down by using a Forstner bit and a 1/2 drill bit. I also beveled the edge. I’m making one for my grader blade too. All this means is that we will not get snow this year.
   / What did you do on or to your LS Tractor today? #2,122
alot of us must be getting for the snow to fall ,, i fabbed up a quick attach and made a mount to use my 68" snow plow off of my Rhino so now i should be able to move snow with either machine .
Jake
   / What did you do on or to your LS Tractor today? #2,123
Well here's my regen history the best I have record of it, I'm sure I missed a few early on before I recognized there was a real problem. I have been having issues almost since I picked it up. They replaced a sensor, and they now have a ECU on order (backorder.) I even had a few regens and then within 5 minutes it goes into limp mode which a restart clears. There were also a couple regens ran at the dealership during troubleshooting and maintenance which I don't have listed below.
Regens time on hour meter, all regens complete successfully ~12 minutes:
4 (ran by dealer due to error code, day after I brought it home)
101
106
112
118
119
148
165
175
187
191
197
213
224
234
At one point, LS time told my dealer who told me they did NOT think the regen frequency was abnormal!
They have also blamed the fuel quality, which I get only from 2 sources with high turnover. I told them to sample it and prove the fuel is bad. After that, they ordered parts lol
That is way too frequent. Have they resolved the issue yet? Maybe a faulty post pressure sensor?
   / What did you do on or to your LS Tractor today? #2,124
I just finished putting on the snow chains, In a blizzard. Took me 3hrs. These few storms and cold weather has kinda taken me by surprise. But, now I'm ready for winter. (Probably going to start warming up now. 😒)
   / What did you do on or to your LS Tractor today? #2,126
Moved the SMV and put on an implement chain support and hook loop.
   / What did you do on or to your LS Tractor today? #2,127
Nice move but can you still open the rear window ?
   / What did you do on or to your LS Tractor today? #2,129
Thanks for the picture ! Looks pretty slick, I might have to try the same thing because where my SMV sign is now it interferes with the hoses for the hydraulic top link.
   / What did you do on or to your LS Tractor today? #2,130
I’ve been trying to figure out where to relocate mine too ( it’s off right now) for the same reason ( interference w/hydraulic lines for T&T). Never looked at the strut attachments-great idea.
2014 Freightliner 108SD Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2016 F-250 4X4 (A56435)
2016 F-250 4X4...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
VACUUM PLANTER PLATES (A52708)
VACUUM PLANTER...
flooring (A55758)
flooring (A55758)
